Author Topic: Vacuum at idle?  (Read 1669 times)
Offline lime73
Vacuum at idle?
« on: November 14, 2011 - 04:52:23 PM »
Is anyone else using Mopar Performance cam#P4452993 Purple Shaft?   If so are you having problem getting good vacuum at idle?  i am only able to get about 10-12in at 900rpm idle.   If this is normal i am going to have to add a vacuum canister for power brakes.  Any thought on those??
Offline ireland383
Re: Vacuum at idle?
« Reply #1 on: November 14, 2011 - 06:00:40 PM »
I'm running a Comp cams 275DEH with I think 482 lift and have 12 vac at idle with power brakes. No problems with the brakes. What Mopar cam is that? 484. Are you having trouble with your brakes?
1971 Plymouth Barracuda
Offline 72cudamaan
Re: Vacuum at idle?
« Reply #2 on: November 14, 2011 - 06:30:22 PM »
12 in should be plenty for brakes.
If I cant fix it, it's broke
Andy  (phukker whither)
Re: Vacuum at idle?
« Reply #3 on: November 14, 2011 - 06:39:24 PM »
That sounds about right for vacuum , is the timing set around 16* at idle ?
Offline 74CudaDave
Re: Vacuum at idle?
« Reply #4 on: November 15, 2011 - 09:45:34 AM »
Yup, I have that cam and that's about what I get at idle. Can you get your's to idle in gear lower than 1000 rpm?
Offline oldkimmer
Re: Vacuum at idle?
« Reply #5 on: November 24, 2011 - 11:07:52 PM »
.................Thats about normal 4 that cam.................dont forget that factory cams only pulled 15-16 inches of vacc.............kim..........
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
