Author Topic: trunk lock and rod for a 1973 cuda  (Read 660 times)
Offline survivordude
« on: November 18, 2011 - 03:15:52 PM »
Ok guys,Im tired of buying the wrong parts for this car,I have a 73...i just bought a for a 70-71 cuda...the rod from the lock to the latch is way to long...so Im taking it that theres a difference?anyone have a clue where to get the EXACT right one?PLEASE HELP ME...UGGGGGGGHHHHHHHHHHH....LOL
Offline FY1Cuda
Re: trunk lock and rod for a 1973 cuda
« Reply #1 on: November 18, 2011 - 04:27:05 PM »
After putting a new tail panel and practically everything else back on our '70 Cuda, we found that the lock rod was about a 1/4" too short for some reason.  Went to the hardware store and bought a 3/16" diameter rod and made one to the length I needed.  That's the easiest solution, and the rod will be under $2.  You can also cut the one you have, put the right angle bend in it, and you've saved two dollars.
« Last Edit: November 18, 2011 - 04:31:03 PM by FY1Cuda »
« Reply #2 on: November 18, 2011 - 05:34:38 PM »
thanks...I"made"the rod work but its way longer than just a 1/4 "
