Author Topic: Body Plug Holes - Why shouldn't I weld these ugly holes up?  (Read 1785 times)
Offline CudaDownUnder
« on: November 18, 2011 - 04:09:27 PM »
Hi Everyone,
Why do cars have holes in the floor/trunk that are filled with rubber plugs?
The reason I ask this is that I have my Cuda on a rotisserie at the moment and got to thinking "why shouldn't I weld these ugly holes up?"
My initial thought was to let water out if the car got flooded but some holes are on high areas where water would not sit.
Are they used on the production line for alignment? Some of them could be used to access underlying areas, I suppose.
Any thoughts/facts?
« Last Edit: November 19, 2011 - 12:02:37 AM by CudaDownUnder »
1973 Plymouth 'Cuda
Re: Body Plug Holes - Why shouldn't I weld these ugly holes up?
« Reply #1 on: November 18, 2011 - 04:22:49 PM »
I think most are drain plugs, but I have a 70 Challenger. You need to have access to the top of the rear shocks on my car. The plugs probably varied over the years and make of car.
Offline PlumCraZRT
« Reply #2 on: November 18, 2011 - 04:25:59 PM »
I've been wondering the same thing...   :popcorn:
The only purpose I see them having is breaking and getting my carpet wet when it rains (then eventually rusting the floorboards).
mmmmm.... Mopar.... *drool*
Offline tommyg29
« Reply #3 on: November 18, 2011 - 04:50:00 PM »
if you want your car to retain factory originality then obviously keep the plugs. If not, go for it, although some are needed for accessing things like the rear shocks, etc.
« Reply #4 on: November 18, 2011 - 08:53:18 PM »
I wonder,......has anybody ever had to remove these plugs to drain their car? If you did, what kind of s&^% did you get into?
« Reply #5 on: November 18, 2011 - 11:33:28 PM »
Right before the cars were painted, they were dipped in huge pools of degreaser, rust protectant and primer.  They had to get the excess material out of the car.
I'm sure most of you have noticed a visable line on the inside of your cars if you've ever had the interior completely out.  That's the dip line.  The bottom half of the car was dipped in a rust protectant.  I often wonder how rusty these cars would be if that hadn't been done.  It sure didn't stop any rust that I can see. :lol:
Here's a picture from PCG's website showing a car being dipped.
http://www.performancecargraphics.com/Paints_Dyes/Dip_Tank_Primer.htm
« Last Edit: November 18, 2011 - 11:44:37 PM by burdar »
« Reply #6 on: November 22, 2011 - 05:37:25 PM »
Thanks for your replies.
Here's a summary:
1. The holes were there to drain paint from the body during the factory dunking process - I won't be dunking so that's not a problem.
2. Originality - I'm doing a restomod so that doesn't concern me.
3. Access to rear shocker mounts - I haven't decided if I'm going with leaf springs or a 4-bar set-up so I will keep that in mind.
The only deterent now is that I have to make all the metal circles to weld into the holes... :stomp: any time saving ideas?
1973 Plymouth 'Cuda
Offline mopar12372
    • mopartech
« Reply #7 on: November 22, 2011 - 08:28:20 PM »
use different size hole saws to make perfect circles , thats if you could find the size hole saws for the proper hole.
RESTO PICTURES
« Reply #8 on: November 23, 2011 - 04:07:13 AM »
I just had a brilliant thought...
I can cut the metal surrounding the round holes and make them into square holes -  then the square patch pieces will be far easier to make!  :bananasmi :bananasmi :bananasmi
1973 Plymouth 'Cuda
