Author Topic: Having trouble boiling fuel in traffic, what do you think about this solution?  (Read 2690 times)
Offline hemiken
 :2thumbs: go the STR14 Brad :jumping:
If you did run the intake you modified, and what an amazing thought process, you could run a tube to a cold air box that holds ice, only if Canada weather is not cold enough of course............... :dunno:
 :roflsmiley:  it does get hot here in the summer too! You know.... causes our igloo's to melt! :naughty:
Just hook up a bottle of Liquid Nitrogen to that fogger unit and watch things cool down!
Offline 73EStroker
Brad, what I do to prevent boiling fuel is run a Mallry 110 pump at the tank area, 3/8 line to a bypass regulator on the right inner fender by the engine, 3/8 line to the carb, bypass 3/8 line back to the tank which enters near the top of the fuel filler tube. So at idle it is pumping about the same back to the tank as is going towards the engine minus the idle fuel consumed. I also have a Mr Gasket fuel log at the carb and I take a 1/4" line off that back through the original vent line back to the tank pickup unit. That 1/4" line is restricted in the fitting at the fuel log by using a pop rivet (with the mail removed) stuffed inside the fitting. So this gives a recirc of cool fuel virtually to the carb. So on 40 deg C days (thats 100F for you southern dudes) in Salmon Arm I can idle as long as I want. Only thing though is it is a bit finicky after sitting for like 20 minutes in those temperatures at startup and slow running for about a minute until the hot gasoline is expelled back to the tank. I am also contemplating firesleeving the lines where they come parallel to the right side header as that is a large source to pickup heat. So far absolutely no issues running in summer temps.
Hope this helps. Love your casting and yes you picked the best manifold for a 4 barrel setup IMHO.
Barry - and I finally located the literature on the hydraboost setup so will scan it all on Monday week (5th Dec) and send - honest.
Barry (Salmon Arm)
Ya I have a new Mallory electric pump new in the box from a past project that never got used , Yesterday I ordered a reg with a by pass on it so I can run a return line. Looking forward to your hydroboost info too! Got one from a GM Astro van this summer so I could use all the tips/info I can get. :2thumbs:
Funny thing is I just bought a STR intake so I might not use this after all If I can get it to work on the street?
