Author Topic: 1971 cuda bumper brackets hit grill?  (Read 2079 times)
Offline culp71
« on: November 21, 2011 - 11:13:31 AM »
hey all
putting together 71 cuda, (using with some parts i thought were 1970), while trying to install grill (PPR)
it has 4 reliefs cut out of bottom mold, for bumper bracket clearance i would asume. but my bumper brackets inner supprts don't line up with grill reliefs, outers fit perfectly but inners dont line up, is it possible that i have a different year bumper brackets, were all 70-74 the same or only 70-72 then 73-74 same?
any help would be great
Offline dutch
Re: 1971 cuda bumper brackets hit grill?
« Reply #1 on: November 21, 2011 - 01:04:48 PM »
show us some pics of what you have.  got any parts#`s?
*** Bart ***
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: November 21, 2011 - 05:15:40 PM »
They are different.  I believe 70-72 are the same and 73-4 had different ones since the grill is pushed out for the bumper inpact steel insert and filler piece.    What part number do you have on the current brackets?
Offline culp71
« Reply #3 on: November 22, 2011 - 11:27:11 AM »
cant make out any part #, however heres some pics and there was a set of bumper bumpers (horns?)
on front bumper which i thought only 72-74 hade but
here some pics
also is the front valance that close to bumper bracket bolts on bottom?
thanks
Offline culp71
« Reply #4 on: November 22, 2011 - 11:28:47 AM »
see  on pics how the inner 2 relief moulds in grill dont line up with bumper brackets outer 2 perfect but inner 2 dont line up accually hitting and pusing grill up, i just have sitting in there so as not to stress anything.
« Reply #5 on: November 22, 2011 - 12:16:16 PM »
Look at the bumper...I can see where the large 73-74 bumper guards used to be.  You probably have the wrong brackets too.
Offline dutch
« Reply #6 on: November 22, 2011 - 12:45:56 PM »
I don`t recall seeing the bolts go through the top of the bumper on a 70 or 71... not sure on other years though  :clueless:   are you sure left & right inner brackets aren`t mixed up..?
*** Bart ***
Offline FY1Cuda
« Reply #7 on: November 22, 2011 - 02:15:10 PM »
As Dutch said, they're shouldn't be any bolts on the top side of the bumper.  The inner brackets should go through those notches and then bend inward to meet the bolt holes on the bottom of the bumper.
Our '70 inner brackets have numbers on the inner back end (which is where the rust tends to form).  One of the numbers is 29622?0 35756.
« Reply #8 on: November 22, 2011 - 02:21:13 PM »
He has 73 or 74 bumpers and brackets.  You can see where the large bumper guards were.  The 70-72 bumper brackets most likely won't bolt to a 73 or 74 bumper.
« Last Edit: November 22, 2011 - 02:22:52 PM by burdar »
Offline Mopar_Mudder
  • I'm a llama!
« Reply #9 on: November 23, 2011 - 02:31:14 PM »
Yep wrong bumper. Shouldn't be any bolts on top
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Offline culp71
« Reply #10 on: November 23, 2011 - 03:34:39 PM »
thanks all , I had a feeling but now i know for sure!
