Author Topic: 4 Speed Floor Hump  (Read 2991 times)
Offline larry4406
4 Speed Floor Hump
« on: November 24, 2011 - 01:58:37 PM »
I am getting ready to cut the floor for installation of the floor hump.   My car has original floor pans and is a 71 barracuda.  The hump is an original piece, not sure of year that I got it out of 25 years ago.
Any event, there is a gap between the hump and the floor.  Same as in the pictures below I stole from Noob's resto thread.
What is up with this gap and how to close?  Is the repo hump  for a specific year floor?  My floor and hump look just like these.
Offline ksierens
    • 70 Challenger Resurrection
Re: 4 Speed Floor Hump
« Reply #1 on: November 24, 2011 - 02:26:09 PM »
Just take a 2x4 and a hammer and pound it flat to the floor, or use a hammer and dolly.
Kurt - SE Michigan
Offline GranCuda1970
« Reply #2 on: November 24, 2011 - 04:27:03 PM »
I still need to do that!! ! Should have done it first.
Offline vinb
« Reply #3 on: November 24, 2011 - 05:40:47 PM »
My 73 'Cuda floor pan a little different??
Offline larry4406
« Reply #4 on: November 25, 2011 - 10:03:06 AM »
Yea i get the bfh technique and will head down that path.  I had heard there was a '70 floor pan style, and then a 71-74 floor pan.  My 71 does not have the rib that his 73 does to match the hump.
Offline rhamson
« Reply #5 on: November 25, 2011 - 10:21:47 AM »
My '72 Challenger had the bump in the floor yours seems to be missing.  My tunnel was from AMD.
Offline Challenger III
« Reply #6 on: November 25, 2011 - 03:15:03 PM »
My 4 speed hump install (AMD):
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline larry4406
« Reply #7 on: November 25, 2011 - 04:08:13 PM »
Challenger III - I actually printed out your picks to guide me, thank you for posting.  In your pric's, it looks like you offset your floor cut by about 3/4 inch relative to your perimeter tracing based on scaling the photo.
The original hump I have (not sure what year or frankly if cuda or challenger, been 25 years since I liberated it with a cold chisel and hamer) seems to indicate about 1/2 inch offset along the centerline of the transmission while the other edges are about 3/4 inch.  This based on the pattern of rust and overspray of undercoat.
« Reply #8 on: November 25, 2011 - 04:42:35 PM »
This sounds about right. I will trim excess around the opening when my car is on the rotisserie. I'm actually not positively sure how the factory did it, I am going to go by what will look the best appearance - wise. I'm happy I could assist to the degree I could. :cheers:
