Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Speedo Cable firewall grommet
« previous
next »
Print
Pages: [
1
Author
Topic: Speedo Cable firewall grommet (Read 923 times)
peterro
Full Member
70 Challenger in progress...
on:
November 27, 2011 - 08:46:01 PM »
I have a new set of grommets for the body of the car and one of them is for the speedo cable. The old one was looking pretty ragged. Looking at the grommet, the center hole is very small and I'm not sure how to get it back on. The speedometer end of the cable is a LOT bigger than the hole in the grommet and the trans end is even bigger. Any thoughts?
Thanks again.
Logged
Grec
The '73 Chrysler should have made...
Full Member
Re: Speedo Cable firewall grommet
Reply #1 on:
November 28, 2011 - 09:05:11 AM »
That's a tough one.
The replacement speedo cable I got had the grommet already on the cable. I can't see how you'd get it on there once the ends have already been put on...
Logged
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
burdar
Sr. Resident
Reply #2 on:
November 28, 2011 - 09:24:32 AM »
I ran into the same thing with the speedo cable. I just cleaned up my original one because I didn't want to risk breaking the plastic end. I'm sure they expand more than you think though. Can you try spraying some lubricant on them to aid the installation? I didn't think my new E-brake cable grommet was going to stretch over the cable end but it did. I think I sprayed some penetrating oil on it first.
Logged
JayBee
Resident
Reply #3 on:
November 28, 2011 - 09:41:06 AM »
You probably thought about this already, but I'd leave the original one on while trying to install the new one, just in case it gets wrecked. If you get the new one on successfully then you can just cut the old one off.
Logged
John
1970 Barracuda convertible
2014 Toyota Avalon
peterro
Full Member
Reply #4 on:
November 28, 2011 - 11:53:46 PM »
I probably should have left the old one on but I got a bit ahead of myself. I didn't really want to but as a last resort I was thinking of slicing it and putting it on directly. Not really the best choice but I'd think it would seal pretty tight.
Logged
Cuda Cody
Resident
Vancouver, WA
Reply #5 on:
November 28, 2011 - 11:56:13 PM »
Don't cut it! It will pull right on easier then you think. Install it from the end that goes to the back of the speedo. You can use some lube if it makes you feel better.
Logged
peterro
Full Member
Reply #6 on:
November 29, 2011 - 12:45:15 AM »
Well it wasn't especially easy but it did go on. Went out to the shop to give it another go. Put some lube on it and it stretched enough. It did tear the center part of the grommet a bit but I turned that side down to not be visible.
Thanks.
Logged
Grec
Full Member
Reply #7 on:
November 29, 2011 - 08:54:07 AM »
"You can use some lube if it makes you feel better"
That's what SHE said
Logged
- 440 Six Pack
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
