Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Fuel Line
« previous
next »
Print
Pages: [
1
Author
Topic: Fuel Line (Read 1530 times)
JoltinJoe
Full Member
BALZ TO THE WALZ MAN
Fuel Line
on:
November 29, 2011 - 05:26:50 PM »
Looking for a short term fix-it. Is there a problem with going from the main fuel line to mechanical fuel pump to filter to carburetor with just rubber hose?
Logged
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
RB2929
Full Member
Re: Fuel Line
Reply #1 on:
November 29, 2011 - 05:38:53 PM »
I have used the rubber tube. Make sure that it is gasoline compliant. Get steele as soon as you can, though
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re: Fuel Line
Reply #2 on:
November 29, 2011 - 07:07:30 PM »
That's the way I have mine setup. But every 4-5 years I replace the rubber lines because the ethanol in the gas now eats them up.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
Chryco Psycho
Administrator
C-C.com Guru
Re: Fuel Line
Reply #3 on:
November 29, 2011 - 09:43:43 PM »
the hose may not last long with ethanol fuels
Logged
LAA66
Sr. Member
Re: Fuel Line
Reply #4 on:
November 29, 2011 - 09:49:24 PM »
How much rubber fuel line are you thinking about. Tank to pump
Logged
73EStroker
Sr. Member
Re: Fuel Line
Reply #5 on:
December 08, 2011 - 09:46:47 PM »
Use teflon lined hose like they do with aircraft
Logged
Barry (Salmon Arm)
burdar
Sr. Resident
Re: Fuel Line
Reply #6 on:
December 09, 2011 - 09:16:10 AM »
I wouldn't run that much standard fuel hose. Just go to a parts store and buy a cheap section of fuel line. Bend it up to fit...it doesn't have to be pretty. The potential risk of fire isn't worth it IMO. A 69 Road Runner burned at the Mopar Nats on Brice Road a few years back. I'd hate for that to happen to you.
Logged
JoltinJoe
Full Member
Re: Fuel Line
Reply #7 on:
December 12, 2011 - 02:43:48 PM »
This will just go from the main to the pump to the carberator. Literally to drive it to the paint shop (hell of a time for the Fuel Pump to go). It will be getting an entirely new fuel system immediately after. So cheap is my angle. But if I find the need for any rubber, it will be Teflon.
But guys I am having one helluva time finding the Fuel Pump adapter. I bought 5/16th to 5/16th male and it leaves 2/16th thread sticking out. That can't be correct... I have searched and searched and searched but all emails, calls and stores shoot me down. Every internet thread ends with no answer:
http://www.cuda-challenger.com/cc/index.php?topic=36012.msg360772#msg360772
Logged
Aracer
Jr. Member
Re: Fuel Line
Reply #8 on:
December 18, 2011 - 03:07:34 AM »
I like cheap 3/8" aluminum for easy hand forming and double flair fittings. $1/ft'
Summit has the inverted flair nuts. Hardware store has the rest.
http://www.summitracing.com/search/?keyword=Summit%20Racing%20%20%20%20Flare%20Tube%20Nut&dds=1
5/16" pipe to 3/8 flair nut, using 3/8 aluminum tubing, and get a Summit double flair tool kit. I used a rt. > adapter to go up to the carb, and the inverted nut into the Holley fuel line. Tubing can be routed over dist.
Last Edit: December 18, 2011 - 09:32:12 PM by Aracer
Logged
usraptr
Sr. Member
Re: Fuel Line
Reply #9 on:
December 18, 2011 - 07:13:28 PM »
Did that on my wife's '67 Cougar back in the day and started having vapor lock problems with it on hot days. Just saying....
Logged
1970 Plymouth 'Cuda. Matching numbers 440 U Code, 4 speed pistol grip, Rallye dash, AM 8 Track, Shaker hood, 15 inch rallye wheels, Dana 60 4.10, Super Track Pak. One of 134 - 440 "U" coupes codes built in 1970 and one of 100 - 440 Super Track Paks built in 1970.
Restoration pictures at:
http://spanks4thememory.smugmug.com/Cars/70-Cuda/7240639_M24oi#465274575_2MBqW
(Edited 8-1-17)
"usraptr" = United States raptor - bird of prey = United States Bald Eagle. FYI, somebody else thought of it first so I had to drop the "O" in raptor.
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Fuel Line
