Author Topic: Windshield wiper problem  (Read 8936 times)
Offline TinCuda
    • 'Cuda
« on: December 03, 2011 - 02:15:33 PM »
1971 'Cuda variable wiper:
The windshield wiper turns on and sweeps, when you turn it off, it just stops where ever it is.  It does not return and park.  I had this same thing happen 25 years ago.  I took the car to a local auto electric "mom and pop" shop and they keep the car for 6 weeks and could not figure it out.  When I got the car back, I took it down to the local dealer.  One of the guys that worked in the service department was a 'Cuda nut.  He owned 3 or 4 'Cudas and was the shop's E-body expert.  He had my wipers fixed in one afternoon.  I know that the first guys replace the switch in the dash and it did not help.  I also believe that the wiper motor was NOT replaced.  I don't remember it costing very much to fix.  I was in school at the time and was on a budget from only working a part time job.
Anyone have any ideas?  It is doing it again.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline Jamiez
  • Retro
Re: Windshield wiper problem
« Reply #1 on: December 03, 2011 - 02:25:49 PM »
My understanding is this is not an uncommon problem.  You should check out this vendor's thread as they rebuild/replace a lot of wiper motors :)
http://www.cuda-challenger.com/cc/index.php?topic=65631.0
Offline TinCuda
    • 'Cuda
« Reply #2 on: December 03, 2011 - 02:39:17 PM »
Yeah, I kind of skimmed through that thread.  It seemed like a lot of business transactions and showing good work results.  I really didn't want to clutter up that thread with my questions.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline swede-cuda
« Reply #3 on: December 03, 2011 - 03:02:12 PM »
 :wave: might be the breaker contact onder the motors lid that needs to be bent toghether some.  :working:
« Reply #4 on: December 03, 2011 - 03:47:36 PM »
usually the park switch inside the wiper motor , contact Kim @ Passion for Mopars  she will get you fixed up , she is in the vendor section
Offline TinCuda
    • 'Cuda
« Reply #5 on: December 20, 2011 - 04:22:45 AM »
Is this something that I can fix myself if I pull this thing apart?
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline Katfish
  • 70 Challenger
« Reply #6 on: December 20, 2011 - 06:30:54 AM »
I'm curious too  :popcorn:
I have similar problem, but mine just don't go all the way down.
« Reply #7 on: December 20, 2011 - 08:05:36 AM »
Contact Kim , if you can repair it she will talk you through it
« Reply #8 on: December 20, 2011 - 08:07:01 AM »
Same here!
Offline passion4mopars
    • Passion4mopars
« Reply #9 on: December 20, 2011 - 08:40:36 AM »
I'm not a sponsor on the forum any longer but that is a fairly easy fix on the "no park" situation.  Usually the problem is not with the switch, etc., it's the reverse side of the switch plate and the contacts
« Reply #10 on: December 20, 2011 - 02:27:35 PM »
Sorry for the newbie question  :-[ but, is this switch plate on the dash switch or in the wiper motor?
Offline TinCuda
    • 'Cuda
« Reply #11 on: December 20, 2011 - 08:24:46 PM »
I don't think that is a bad question.   I'd like to know also.
Seems like when I had this same  problem 20 years ago,  they changed my dash switch with no help.
My memory may have faded a bit over the years.
« Last Edit: December 20, 2011 - 10:00:35 PM by TinCuda »
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
    • Passion4mopars
« Reply #12 on: December 20, 2011 - 09:22:26 PM »
I'm sorry...switch plate = gear housing cover   Sometimes I forget that what I call something is sometimes confusing because others call it something else.  I think it's a matter of me speaking "blondinese" at times    :cooldancing:
Offline footin70rt
« Reply #13 on: December 20, 2011 - 09:35:02 PM »
And now my turn. Is the switch plate repairable or is it a replace item?
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline Aracer
« Reply #14 on: January 23, 2012 - 12:11:47 AM »
There is a ground wire on a speed nut next to the switch in the dash, it's over looked. Mine (1974 2 speed) has the motor harness unplugged so it won't happen again.   :violin:     Just in case the switch is touched.
