Author Topic: wrong filament is lighting.  (Read 1360 times)
Offline 06Daytona
« on: December 04, 2011 - 09:18:38 AM »
On one of my brakelight bulbs the wrong filament is lighting up when I put on my park lights. I've tried reversing the wires, sliding the contacts out and spinning them and it keeps doing the same thing. It's getting me a little frustrated, although at least I have all the lights working on the outside now, except the back up light, but that has to do with the B&M shifter that's in it.
Am I missing something, or do I need to chase the wire farther back towards the front of the car?
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline Cuda54
Re: wrong filament is lighting.
« Reply #1 on: December 04, 2011 - 09:42:22 AM »
What car are you working on? What side of the car?
Offline 06Daytona
« Reply #2 on: December 04, 2011 - 10:10:07 AM »
It's the 70 Challenger, inboard right side tail light
Offline FY1Cuda
« Reply #3 on: December 04, 2011 - 02:26:36 PM »
Some of the two-contact bulb sockets can reverse the wiring if the little disk from the bottom of the socket comes up and out and then is put back in 180 degrees off.  Make sure the socket contacts are where they're supposed to be.
Offline 06Daytona
« Reply #4 on: December 04, 2011 - 07:10:07 PM »
I'm going to go over them again tomorrow. I had them on tonight and I think I have the park lights brighter than the brake lights right now. I did manage to get a headlight switch from a friend and it only cost me one of my 8 alternators. I also picked up a set of original 14x7 Rallye wheels with small caps and rings with brand new tires on today.
Offline Jamiez
  • Retro
« Reply #5 on: December 04, 2011 - 07:20:50 PM »
The rear harness is pretty simple. It connects just behind the kick panel on the driver's side.  You can just rig up a multi-meter there and work the pedals/signals to diagnose it instead of going back and forth to the rear to check them.  Also some year rear harnesses are reproduced (I think 70 and 71).
Offline ShelbyDogg
« Reply #6 on: December 04, 2011 - 07:45:34 PM »
Make sure that you are getting a good ground on the socket.  I solder a ground wire to each socket, then ground the end to the tail panel.
Offline Cooter
    • christinecarclub.com
« Reply #7 on: December 04, 2011 - 11:45:13 PM »
Also make sure the correct bulb is used as well. I can't tell you how many times I've seen '69-'70 Chargers with the inside tail light looking like the damn brake lights are on only on the inside ones.
