Author Topic: Upper steering column bearing  (Read 1904 times)
Offline Beck
    • BECK KUSTOMS
« on: December 05, 2011 - 03:39:33 PM »
Hey guys,
just a quick question regarding the upper steering column bearing:
The ones I can find for sale online all say 70-71 E body.
Did they change the bearing for the later years? I don't think they did, but thought I'd check here first.
Also, where there any changes to the steering column over the years? My 73 cuda has a 70 challenger dash and instrument panel, maybe it's got a 70 column as well...
Cheers,
Aaron
Re: Upper steering column bearing
« Reply #1 on: December 05, 2011 - 03:45:51 PM »
There are some differences but I really don't know much about the internals.  I know 1970 had a different key light arrangement.  1970's also had a shift lockout on the column that later years didn't have.
Offline 72cudamaan
« Reply #2 on: December 05, 2011 - 07:41:34 PM »
Upper bearing is the same for all years. The lower had a few versions, depending on if it was bolted in
with 2 or three bolts. The 74 column uses a totally different bearing set-up with a spring
and retaining circlip.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #3 on: December 06, 2011 - 06:12:43 PM »
Also 71-74 have a different key release mechanism.
Bearing is the same.  You can still get it from Dodge.  Just not the rubber surrounds for it.
I recently bought a entire 74 column just for that lower bearing setup... and it didn't even have the spring... still trying to find that spring.
Almost everything else can be bought easily.
I have 5 e-body columns and a bunch of charger and dart ones for parts.  They almost all interchange.
Ryan
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
« Reply #4 on: December 06, 2011 - 07:41:42 PM »
Aaron and Ryan,
I hunted throught my spare/unused parts and found these? The steering column bearing is from a 70 Challenger column shift? I can measure it if need be. Ryan/ Aaron is this what you need? If so it's yours just PM me where to ship it?
Offline Devil
« Reply #5 on: December 07, 2011 - 12:40:39 PM »
I appreciate the offer, I was able to get one put together.  But by all means if Aaron needs it.
Thank you
Ryan
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
« Reply #6 on: December 07, 2011 - 05:05:56 PM »
Thank you
Ryan
[/quote
No problem! Aaron needs the bearing , I thought you needed the clip/spring thingy.
Offline Devil
« Reply #7 on: December 07, 2011 - 06:24:08 PM »
Ah I see the confusion.
I need the spring setup from a 74 E-bodie lower Bearing.  It is a 1 year only setup and I have yet to find the spring.  But I got the bearing.
Thanks though!
Ryan
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
« Reply #8 on: December 07, 2011 - 07:02:53 PM »
Thanks though!
Ryan
Ah ok wrong part.  Maybe next time.
