Author Topic: Mil Spec electrical connectors....I need an education?  (Read 3663 times)
« on: December 05, 2011 - 09:37:27 PM »
Ok I bought a STR-14 intake and am considering hiding a fuel injection system inside, so I need a connector that has 16 pins, waterproof, holds vaccum, and preferably with a 90 deg socket on one end for the injector wiring. I need a male and female set. Looking on E-Bay to see what's available and see lots of military spec plugs but have no clue on the specs, like will it seal and not cause a vaccume leak?  Second question... anyone know where I would get one? I don't see any with 16 pin connectors...yet?  I figured there are more than a few members on here in or were in the military, thought maybe someone might know?
Something like this.... but with 16 pins and smaller in size?
« Last Edit: December 05, 2011 - 09:46:31 PM by brads70 »
Offline Jamiez
  • Retro
Re: Mil Spec electrical connectors....I need an education?
« Reply #1 on: December 05, 2011 - 09:52:49 PM »
You might find http://en.wikipedia.org/wiki/U.S._Military_connector_specifications educational
You can use the numbers to find documents like this:
http://www.landandmaritime.dla.mil/Downloads/MilSpec/Docs/MIL-DTL-26482/dtl26482.pdf
Which should cover everything you need to know :)
« Reply #2 on: December 05, 2011 - 10:39:23 PM »
Thanks! I found similiar  stuff. I've figured out I need it to be" hermetic sealed".  Still trying to locate a supplier.....
« Reply #3 on: December 05, 2011 - 10:57:08 PM »
I'm missing something here. I use those type of connectors all the time at work, but vacuum? They are electrical connectors. Don't see how they could cause a vacuum leak.
However, misunderstanding aside, I'll check and see if I can source a couple 16 pin connectors.
« Reply #4 on: December 05, 2011 - 11:24:02 PM »
I just meant that they will not leak when installed in the intake (Like through the electrical connections?), causing a vacume leak. I plan on machining a hole and mounting the connector to the intake , then with the other end plugging in the harness.   Hard to explain, but I hope you understand what I'm trying to say?  :crazy:
Thanks for looking for me! :2thumbs:
« Last Edit: December 05, 2011 - 11:57:40 PM by brads70 »
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #5 on: December 07, 2011 - 02:22:45 PM »
i have an old mopar magazine where the did the exact thing you want to do in it. not sure if thats where you got the idea from but it is a good idea.
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
« Reply #6 on: December 07, 2011 - 03:48:26 PM »
Neil (CP) put the bug in my ear Hemiken posted a picture of a crossram turned into FI
http://www.moparmusclemagazine.com/techarticles/mopp_0902_port_injected_cross_ram_manifold/viewall.html
Offline the_engineers
« Reply #7 on: December 08, 2011 - 10:44:22 AM »
I used to build cabling for farm equipment gps. we back-filled the connector housings with silicone sealant after assembly and used a vacuum test to ensure integrity.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #8 on: December 08, 2011 - 04:07:58 PM »
Ya  that's my plan too after I solder in the wires . Either silicone or epoxy to seal it. Here is what I just bought off e-bay, cheap ..$14  for 2 sets ?
« Reply #9 on: January 03, 2012 - 05:52:03 PM »
They just arrived today. They look good and should do the job! :2thumbs:
