Author Topic: questions on charging, Alt, Reg Etc  (Read 3762 times)
Re: questions on charging, Alt, Reg Etc
« Reply #15 on: December 09, 2011 - 08:51:21 PM »
What if this occurred? Would not a fuse at the battery be appropriate :clueless:
That would be the same as the stud on your starter relay coming loose. It's not fused either. It comes down to the length of wire from the battery. Is the extra 36" a risk? If you consider it a probable cause of a fault, fuse it. It's like the priest's holy water. Might not help, but it won't hurt. IMO, the wire to your starter is much more likely to be the source of a problem. It regularly carries VERY high current and comes close to your exhaust manifold/hedder, is unprotected, and large enough gauge wire to really carry some serious fault current.  :2cents:
Offline GoodysGotaCuda
« Reply #16 on: December 10, 2011 - 07:29:53 AM »
So a fuse would simply protect that section of wire between the two sources?
I'll bet that aftermarket wire goes straight to the battery. If that stud shorted to the casing of the alternator, you'd have a fire on your hands pretty quickly..
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #17 on: December 10, 2011 - 09:16:20 AM »
I'm thinking the only way that could happen is if you are working in the engine compartment and accidentally hit the O/P stud with a ratchet. Pretty hard. Appears to be a staged photo to exhibit a highly unlikely scenario. Certainly didn't break from over tightening.  ::)
« Reply #18 on: December 10, 2011 - 10:31:11 AM »
...not staged
http://www.cuda-challenger.com/cc/index.php?topic=81406.msg815578#msg815578
1976 Dodge Warlock
« Reply #19 on: December 10, 2011 - 11:37:29 AM »
...not staged
Then I change my opinion, I'm wrong. Fuse link it. Although for short circuit protection, I'm thinking two or three parallel #14 fuse links?
« Reply #20 on: December 10, 2011 - 11:45:33 AM »
I use a 100a marine circuit breaker on mine.
1976 Dodge Warlock
Offline LAA66
« Reply #21 on: December 10, 2011 - 02:14:26 PM »
 Would a fusable link section directly off the alternator be OK?
« Reply #22 on: December 10, 2011 - 02:32:11 PM »
It's always suggested that the fuse/circuit protection goes as close to the power source (in that case the battery) as possible.
1976 Dodge Warlock
Offline LAA66
« Reply #23 on: December 10, 2011 - 04:40:23 PM »
 Thanks, I have one coming off the relay which is as close as possible. Couldn't hurt to put one directly off the alternator for the charging feed also. :thumbsup:
« Reply #24 on: December 11, 2011 - 06:56:25 AM »
Any chance you checked to see if a breaker that large would trip on arcing? I realize it's main purpose is short cct protection, but just wondering.
I was looking at this also. Opinions? I was thinking it would get rid of the multiple wires under one nut problem.
« Last Edit: December 11, 2011 - 09:23:05 AM by dodj »
