Now electrics is not my strong point . The charging has always been a bit whacky..at one point I was charging at 14.75+ so I replaced the reg [gen Mopar] didnt change
still a bit on the high side...Since fitting the HEI ignition things are all over the place too. What I do know I that Im loosing a good .75 volt by the time it gets to the battery ..MMm? I went the auto electrician and of course with the A/c on and lights etc barely makes 12 volts at the battery. He suggested to run a wire direct from the Alt to the battery. Im thinking about it
..Does that now bypass the Reg or does the Reg, regulate at the Alt somehow ?
