Finished the driver's side door. Probably the best panel on the car. It needed very little filler. Two small rust spots that I drilled out and welded.
On the driver's fender, I tried the method that is in the last issue of Mopar Muscle. I sanded the entire surface, then used Muratic acid. It came out pretty good. It cleaned out much of the small pitting that was in the fender and also brought to my attention a few small spots that needed to be cut out and welded. I was going to use ospho on it next but I have been reading some issues with filler not sticking well to it after it has been treated. Anyone have any experience with adhesive issues when using ospho?
This is what I had to deal with.
This is what it starts to look like after you treat it.
Door stripped down and ready for filler.
