Author Topic: 72 Cuda Resurrection  (Read 76591 times)
Offline Edison1970
Re: 72 Cuda Resurrection
« Reply #45 on: November 25, 2012 - 07:13:24 PM »
I haven't posted any progress for a while.  Starting to get thing going again.  Applied some filler over the welds on the inner fenders and fire wall.  Removed the passenger side door today and stripped the door jam areas.  Didn't look too bad.  Seems that where ever there was seam sealer, there was rust.  Roof rail area has some little holes coming through that I will have to patch.  One trick I used today to remove the roof rail trim was to heat it with a benzo torch and the glue was soft enough to pull the trim right off without distorting it.  Also made the holes for the cowl screens.  The aftermarket piece had no mounting holes.
Offline Edison1970
« Reply #46 on: December 10, 2012 - 10:54:49 PM »
started to weld up the holes I made in the roof today.  Not bad.  Getting a little better with the welding.  Hope to get all three patched up by this weekend.
Offline cudamadd
    • cudamad157071@gmail.com
« Reply #47 on: December 10, 2012 - 11:46:36 PM »
What a great job , It takes a lot of guts , sweet and pain to  do this . I take my hat off to you. Been there with one of my ebodys . WHEN ALL SAID  and done you will be a very proud in all the work that has :2thumbs: gone into this labor of love . Please keep us up to date .cheers  :aussie:
Go 4 a spin Ya Why Not.
Offline Edison1970
« Reply #48 on: December 11, 2012 - 09:25:22 PM »
Thanks for the positive feed back.  This has been a great challenge.  Never welded myself before until this project.  I think the quarters and the trunk will be easier compared to the patch work I'm doing now.
Offline mrbill426
    • All Around Mopars
« Reply #49 on: December 14, 2012 - 11:17:24 PM »
That's LOT of work, looking good though  :thumbsup:
We're in the middle of a '72 restoe too and know how long it can take.
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline Edison1970
« Reply #50 on: December 15, 2012 - 07:31:53 PM »
Finished all patching over the passenger side roof.  A real pain.  There was a spot that I missed that was weak and I blew a hole through it.  Just ended up taking me longer than I wanted.  Started to strip the paint on the lower rear quarter panel.  I expected to find more than I did.  In front of the rear wheel, there was some rust but
not all the way through.  I'm thinking I will cut it out and patch it.  Am I being to cautious?
Here is a picture of the rear quarter behind the wheel.  Looks like some one backed over a garbage can.
A lot of small rust spots.  Only a few go all of the way through but I think I am going to cut it under the side marker light and put a patch panel in.
Offline mrbill426
    • All Around Mopars
« Reply #51 on: December 16, 2012 - 12:18:57 AM »
I don't think you can be too cautious with rust  ;)
MOPAR or NO car!
Offline dutch
« Reply #52 on: December 16, 2012 - 03:57:20 AM »
 :iagree:   the panel behind that area will have rust  :grinyes:
*** Bart ***
Offline GranCuda1970
« Reply #53 on: December 16, 2012 - 09:55:10 AM »
How many colors has that car been in it's life ? Mine has been two! deep burnt orange and red eventually limegreen. Looks like that one has been at least 3 or 4 different colors.
Offline Edison1970
« Reply #54 on: December 16, 2012 - 11:32:36 AM »
The original color was blue, then hemi orange then a teal color.  I'm taking it down to bare steel on the outside and painting it a dark metalic blue.
Offline larry4406
« Reply #55 on: December 16, 2012 - 05:35:39 PM »
good work.  looks like petty blue (basin street blue) originally.
Offline Edison1970
« Reply #56 on: December 16, 2012 - 06:02:43 PM »
Wow!  I can't believe my car looked like that at one time.  Well, now back to reality.  I figured that I need to order a patch panel for the passenger side so I better check the driver's side and possibly order them both at the same time if needed.  Looks like the driver's side might need a complete quarter panel.  Behind the rear wheel on the lower part is shot.  Small hole in trunk drop off.  The worst part is the 1/4" load of bondo starting at the rear of the fender lip and continuing up the panel.  Looks like some one smacked a wall.  Also, the front of the lower quarter has 2 holes in it.  What do you guys think about a skin or complete quarter?
« Reply #57 on: December 16, 2012 - 11:34:55 PM »
Do the whole quarter panel. It's ton of work but when you're done; you'll be glad you did.
Offline Edison1970
« Reply #58 on: December 17, 2012 - 05:26:07 PM »
I have a 2 piece trunk pan that was given to me with the car.  Should I replace the pan after I replace the quarter panel?  Before I remove the quarter, should I make sure the drivers door is aligned?  Should I take any measurements before I cut it off?  Sorry to ask so many questions but this is a first for me.
Offline 72cudamaan
« Reply #59 on: December 17, 2012 - 09:21:49 PM »
Yes definitely make sure the door is lined up properly and the hinges are tight. ie no sag.  Then
when you mock up the quarter panel, you can line it up to the door and know it is correct.
If I cant fix it, it's broke
Andy  (phukker whither)
