Author Topic: Help me pick a cam for my 440  (Read 2091 times)
Offline edl94
  • She Cuda
« on: December 11, 2011 - 05:03:56 PM »
Need help picking a cam. 440 10to1 comp. Holley Street Dominator Intake, Headers, stock 516 heads, 4.11 gears, TCI Saturday Night Special converter 1800 to 2000 stall. I know this engine could use a good set of heads, they are in my future plans.  I want to hear a little cam in the idle, but not too radical. I am not good with cam specs the numbers make my head spin.
Thanks
Re: Help me pick a cam for my 440
« Reply #1 on: December 11, 2011 - 05:20:37 PM »
Lunati VooDoo 60303 should suit your needs assuming the converter will go to 2200
 the 60302 would work better if the converter is 1800 stall , given the 4.11 gear the 60303 would be my choice . this is assuming you want to stay with hyd cam .
 Installing hard seats & 1.81 exhaust valves will make a big difference using the heads you have with some port work
Offline edl94
  • She Cuda
« Reply #2 on: December 17, 2011 - 10:45:35 PM »
What kind of idle can i expect with the 60303 cam?
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: December 18, 2011 - 09:47:04 AM »
bit faster than stock...mine is pretty smooth and very drivable.  But, having the converter that Chryco suggested (and Lunati as well) probably the reason it works so well.  The actual specs of the cam are not wild for a 440 sized engine and this cam seems to be one of the most popular upgrade cams for  a street car as a result.
Offline MizzouRT
YouTube video of 60303 in 440?
« Reply #4 on: December 18, 2011 - 11:31:05 AM »
Is there a video of the Lunati 60303 idling in a 440 anywhere?  Haven't been able to find one.
Daily Driver: 2013 Challenger SRT 6 speed
Toy: 1970 Challenger
« Reply #5 on: December 18, 2011 - 07:04:37 PM »
I would guessyou will be in the 12"+ vacuum range with that cam
Offline Husker Cuda
« Reply #6 on: December 18, 2011 - 08:07:40 PM »
I have a Lunati 60304 that I just pulled from my 512 Cuda with 700 miles on it.  It idled great and had plenty of vacuum for my power brakes.  Mine is a 4 speed but it had plenty of power on the bottom end.  I'd take $75 for it if you are interested.  I'm going to a bigger solid flat tappet cam in mine.
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
