Author Topic: Weld Or Epoxy.  (Read 923 times)
Offline ourname
Weld Or Epoxy.
« on: December 11, 2011 - 05:40:05 PM »
What is the opinions on using Epoxy to affix panels over welding.
I think the epoxy method stops any distortion of the panels. I think it would also allow more time to "set" the whole panel while it dries.
A downfall I could think about is that if you do have to "readjust" the panel you are in tough.
Any thoughts.
1966 Charger
1974 Cuda
2005 Daytona
2012 Ram 1500 Sport
Offline 72cudamaan
Re: Weld Or Epoxy.
« Reply #1 on: December 11, 2011 - 07:12:23 PM »
My opinion (not that it's worth much) is... structural =weld it on, otherwise, adhesive.
Though I have heard that the new adhesives are extremely strong and durable.
Plus with the adhesive, you may reduce the corrosive effect of welding.  :2cents:
If I cant fix it, it's broke
Andy  (phukker whither)
Re: Weld Or Epoxy.
« Reply #2 on: December 11, 2011 - 07:35:08 PM »
Some swear by epoxy adhesives. I've never used them before. If I had to do a quarter panel again, I would do the wheel lip to outer wheel house with epoxy.
Offline BIGSHCLUNK
Re: Weld Or Epoxy.
« Reply #3 on: December 11, 2011 - 09:59:30 PM »
I used adhesive for the  rails under the trunk floor/above the gas tank. By now its gotta be 4-5 years ago. Never had a problem....
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Weld Or Epoxy.
« Reply #4 on: December 12, 2011 - 02:49:23 PM »
A former employer of mine did some research on this. We found that the two part epoxy adhesives were actually stronger than the parent metal. Using them produced results similar to welding as far as trensile strength vs the parent metal, that is the material tore before the seams did. However, because much of this technology is new and long, long term impacts are not understood, we never used it to replace structural welding. A big part of that is because we had contractual obligations to provide product that met AWS standards, which are widely understood, but there is no similar organization of standards and regulations regarding adhesives that everyone is willing to agree upon.
Would I use it on body panels, sure, but you need to have lap seams to successfully use it as it will not have the strength to use on butt joints. These lap joints would be visiable on one side and are a point of debris collection (ie rust starters) if left in exposed areas.
Offline dutch
Re: Weld Or Epoxy.
« Reply #5 on: December 12, 2011 - 04:08:52 PM »
I would not get it through tech inspection here. They won`t say it`s not strong enough, just what was welded from factory must be welded again.  Would be different on a car with a chassis.
*** Bart ***
