Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Thoughts on Overhead Valve Spring Compressors
« previous
next »
Print
Pages: [
1
Author
Topic: Thoughts on Overhead Valve Spring Compressors (Read 1011 times)
LAA66
Sr. Member
on:
December 11, 2011 - 07:51:03 PM »
Broke another valve spring today and have decided to replace the whole set. Instead of removing the heads would an OH spring compressor be OK to refit the new springs?
Logged
brads70
C-C.com Expert
Re: Thoughts on Overhead Valve Spring Compressors
Reply #1 on:
December 11, 2011 - 08:33:17 PM »
Sure I've done it a few times. Just make sure the piston is at TDC for each set of springs you remove.
Logged
BIGSHCLUNK
Sr. Resident
Miss NIKKI - were you this hot at 48?
Reply #2 on:
December 11, 2011 - 09:28:23 PM »
I've done valve seals on small blocks pumpin' up cyls w compressed air. I dont think it be an issue. Rap the keeper/retainer once or twice with a mallet just to make sure things are loose before hand.
Logged
[o o o o]
OO
OO
[o o o o]
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
December 11, 2011 - 11:07:04 PM »
Mancini has the best tool I have found to use
Logged
LAA66
Sr. Member
Reply #4 on:
December 12, 2011 - 09:09:10 AM »
No problems damaging the springs with the hooked end of the tool? Thought that might have something to do with mine braking.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
December 12, 2011 - 09:34:45 AM »
the Mancini one bolts down onto the rocker shaft pedestals & just presses down on the retainers, no hooked ends , sounds like the springs are under speced for the cam
Logged
brads70
C-C.com Expert
Reply #6 on:
December 12, 2011 - 01:24:06 PM »
I'd double check the installed height etc...
Logged
LAA66
Sr. Member
Reply #7 on:
December 12, 2011 - 03:16:20 PM »
Thanks all.
(Starting a new topic for spring recommendations.)
Logged
LAA66
Sr. Member
Reply #8 on:
December 16, 2011 - 10:05:56 AM »
Thanks for the link. A little pricy, if I were a mechanic it might make sense. This is hopefully a one time deal. I'm currently working on a home made version using an old rocker and shaft.
Logged
vinb
Resident
Reply #9 on:
December 16, 2011 - 07:40:11 PM »
Approx. $60
http://drcraceproducts.com/catalog.html
Last Edit: December 16, 2011 - 07:48:54 PM by vinb
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
