Author Topic: torque specs  (Read 3087 times)
torque specs
« on: December 12, 2011 - 08:43:13 PM »
Are there torque specs for the caliper bracket bolts?  What about the lower ball joint bolts/nuts?  Those are a lock nut in 73...doesn't use a cotter pin.  Is there a torque for lock nuts?
The caliper bracket bolts originally had threadlocker on them.  I've got some blue threadlocker to use but need the torque spec if there is one.  Thanks
Re: torque specs
« Reply #1 on: December 12, 2011 - 10:22:32 PM »
My '73 service manual list 75-100 ft/lbs for adapter mounting bolts, if that's what you mean by caliper bracket bolts. If you mean the guide pins, 25-35 ft/lbs.
Lower ball joint to knuckle bolts, 160 ft/lbs
« Last Edit: December 12, 2011 - 10:26:54 PM by dodj »
Offline footin70rt
Re: torque specs
« Reply #2 on: December 12, 2011 - 11:01:59 PM »
Correct torque on any fastener is tighten til it breaks, then back it off a 1/2 turn.   :stirpot: :poopoke:
 :bigsmile:
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Re: torque specs
« Reply #3 on: December 12, 2011 - 11:17:16 PM »
Thanks, that's what I needed.  I was refering to the adapter brackets.  I still need to find some new caliper pins.  The ones on E-bay don't fit 73-74.  I think Wade posted a link to some awhile ago but I have no idea where that post is.
Quote
Does anyone remember a commercial(probably more than 10 years ago by now) where a young boy was guiding someone into a parking space?  The boy was like "A little closer...a little closer."  Then the driver hits the car infront of him.  The boy then says..."Right there!"   :lol:
Offline cudazappa
Re: torque specs
« Reply #4 on: December 13, 2011 - 04:13:55 PM »
I may be wrong, but didn't 73 and 74 e-bodies use slider calipers like the A-bodies?
2015 Dart GT - Daily Driver
Offline jimynick
Re: torque specs
« Reply #5 on: December 13, 2011 - 04:20:09 PM »
I can still buy all the brake pieces at my local parts store, (and did) and would suggest you give that a try before the restoration vultures pick any more flesh off your bones.  :2cents:
Re: torque specs
« Reply #6 on: December 13, 2011 - 05:02:16 PM »
Quote
73 uses the long pins.  There are extra brackets that bolt to the spindles.  I'm not sure how the A-body is setup.  Are they like the late B-bodies...the M and J bodies?
Quote
Yes, a lot of restoration companies are just reselling local parts store pieces at an inflated price.  Unless you need exact OE correct parts, the local parts store is definately the way to go.  Last time I checked, Car Quest and NAPA didn't list the new caliper pins/bolts.  Advanced Auto lists them but they are rediculously priced.  I found some at RockAuto for $10.  I'm not sure how many you get for $10.  I assume 2.
Quote
How in the world am I going to get those at 160 ft/lbs without them being attached to the car?  It's not going to happen.  I'll probably just have to snug them up and remember to tighten them the rest of the way once the K-member is bolted in.  75lbs sucked last night on the adapter brackets.
« Last Edit: December 13, 2011 - 05:07:29 PM by burdar »
Re: torque specs
« Reply #7 on: December 13, 2011 - 06:56:22 PM »
My '73 is like burdar's, using the long pins, but I do remember dismantling a '73 that had slider calipers like you are suggesting. It was in the late 80's though. Could have been converted? Or maybe some came that way?
