Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Upper to Lower Cowl Sealant / Spot Weld
« previous
next »
Print
Pages: [
1
Author
Topic: Upper to Lower Cowl Sealant / Spot Weld (Read 2232 times)
CudaDownUnder
Jr. Member
on:
December 13, 2011 - 01:36:28 AM »
Hi All,
I have removed the upper cowl section to attend to some rust issues on the upper and lower cowl sections. That's almost done now so I'm thinking ahead about how I'm going to weld in the replacement upper cowl.
When I removed the upper cowl is was clear that the factory applied sealant between the upper and lower cowls
before
spot welding the two together - see pic below
Has anyone tried to replicate this process? If so, please share your method and the outcome.
Logged
1973 Plymouth 'Cuda
mopardave
Sponsor
Resident
1973 Challenger F8 in and out, 68 383,727 3.23 pos
Re: Upper to Lower Cowl Sealant / Spot Weld
Reply #1 on:
December 13, 2011 - 09:06:55 AM »
i would use 3m panel bonder, IT is as strong as weld, seals, wont crack or shrink, and excess is sandable. good stuff
Logged
Mopar Dave
Rosevillemoparts.com
if I haven't replied to your post or PM email me direct
dradcliffe@mikeriehls.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
CudaDownUnder
Jr. Member
Reply #2 on:
December 13, 2011 - 04:10:43 PM »
Thanks Dave,
I'll try and source some - it sounds like an excellent product.
Can anyone answer this...
How do I apply sealer, press the two pieces together and then spot weld it together without destroying the sealer? Like the factory did.
Logged
1973 Plymouth 'Cuda
jimynick
Resident
Reply #3 on:
December 13, 2011 - 04:40:22 PM »
I'm in bodyshops nearly every day and the only time I've heard of what you're asking was when I was told that the shop applied the bonding agent and with a $30,000, very high tech spot welder, did a few spots while the bonding was still wet. Apparently they'd tried it once it dried and it explodes. What I'm going to do with my cowl when I replace it, is leave a few drilled and ground spots for those welds (mig for me) and let the bond do the rest. Dave wasn't kidding when he said the bond will act as a seam sealer and I'm in the process of rounding up enough of the 3M product to do every seam on the damned rust magnet. That way, you don't need to sweat getting caught in the rain anymore.
Ian
Logged
Challenger III
Sr. Member
Reply #4 on:
December 13, 2011 - 06:30:09 PM »
I saw your post on my resto thread about this subject. Sorry for not getting back to you sooner!
I welded the cowl on with no sealer. I am using NP-1 through a length of flexible tube through the vent openings to seal. I'm not sure how a guy can replicate the "Factory Technique".
Logged
Mike Yakima, Washington
Resto Thread:
http://www.cuda-challenger.com/cc/index.php?topic=66668.0
CudaDownUnder
Jr. Member
Reply #5 on:
December 14, 2011 - 12:52:58 AM »
Thanks for your replies.
It's either 3M panel bonder with a few spot welds or lots of spot welds & NP-1 through a long tube.
I'll investigate these two modern day options.
It still puzzles me how the factory did it though... maybe someone who worked on the assembly line will stumble across this thread and share the secret.
Logged
1973 Plymouth 'Cuda
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
