front brake line routing question
Author Topic: front brake line routing question  (Read 4940 times)
Offline dutch
« on: December 14, 2011 - 09:01:02 AM »
I can`t remember where the front brake lines go...  :clueless:   do they run underneath the front frame rails and back up from there?   anyone got pics of that area?
*** Bart ***
Re: front brake line routing question
« Reply #1 on: December 14, 2011 - 09:05:47 AM »
I think there were a couple different designs.  I'm not sure what years had what style.  Here is a picture of a 70 Hemi Cuda that shows the lines going under the frame.
http://www.moparaction.com/Article/Black_Gold/EPV0091.jpg
http://www.moparaction.com/Article/Black_Gold/Epv0102.jpg
Offline GranCuda1970
« Reply #2 on: December 14, 2011 - 09:56:53 AM »
The 1970 book shows 2 options 1 through above and 1 under the frame rail.
Offline dutch
« Reply #3 on: December 14, 2011 - 10:11:47 AM »
do you know what page of the book?, I can`t seem to find it...  where does the above version go through the inner fender?
*** Bart ***
« Reply #4 on: December 14, 2011 - 10:26:24 AM »
If it goes through the inner fender, it will go through the rubber flap that is held on with the spring clips.  There is a hole/slot in the rubber for the line.
Offline dutch
« Reply #5 on: December 14, 2011 - 10:41:06 AM »
thanks gentlemen  :2thumbs:
*** Bart ***
Offline RB2929
« Reply #6 on: December 14, 2011 - 05:29:32 PM »
Hi Bart-
I’m assuming that you’re building your own brake lines, based upon an early post.
FWIW; my 318 car has the brake lines going through the rubber flap / over the frame rail.  I don’t know why Plymouth ran two different directions with the brake lines.
Eventually you’re going to run the brake lines to the rear.  This link has a lot of pictures that may help you; it did me.  It’s those little things that I can’t remember and seeing the pictures made it all clear again.
Link: http://www.cuda-challenger.com/cc/index.php?topic=62801.0
Don’t forget to post your pics covering the progress.
Take care,
Ron  :cheers:
« Reply #7 on: December 14, 2011 - 10:09:40 PM »
It may be a drum / disk thing. My Gran Coupe had the through the firewall routing from the factory when I had the drum brakes. I switched to front disk and got the under the rail brakelines.
Offline dutch
« Reply #8 on: December 15, 2011 - 03:34:06 PM »
hey Ron,
did yours have disc or drums up front?  I`m trying to figure out what would have been the reason for a different route...  :clueless:  doesn`t make any sense to me  :dunno:
thanks for that link too... I should have taken a ton more pics when I took the car apart... oh well... lesson learned  :misbehaving:  Do you know if the mounting point for the rear brake hose was bolted on?  I saw some that were welded to the body, but mine is missing that bracket... I think there was no bracket when I took it apart  :dunno:
edit:   I just saw a pic of the bracket bolted to the floor...  :2thumbs:
« Last Edit: December 15, 2011 - 03:37:00 PM by dutch »
*** Bart ***
Offline RB2929
« Reply #9 on: December 15, 2011 - 05:43:19 PM »
Hi Bart-
I have drums in all four coners
