Author Topic: Replacing intake soon...gasket question  (Read 719 times)
Offline survivordude
« on: December 14, 2011 - 06:52:56 PM »
this is my first mopar...its a 383...Im taking the 6 pack off of it and replacing it with a torker...first time ive ever changed one on a 383...can I just take the intake off,clean the valley pan and reuse it with new gaskets on top?Im actually mechanically inclined,just wanna do this right the first time so hope this isnt a stupid question...thanks in advamce
Re: Replacing intake soon...gasket question
« Reply #1 on: December 14, 2011 - 06:59:57 PM »
Yes, valley pans can be reused. I put Gaskasich on the valley pan to help with sealing. If you want to use gaskets instead, that works too.
« Reply #2 on: December 14, 2011 - 07:08:53 PM »
the gasket set I think works comes with 2 sets...so should I just use 1 set on the top or take the pan off,clean it and use all 4 gaskets,bottom and top of the pan?if I just use the top.should I use something like copper tack on the gasket surface?...thanks
« Reply #3 on: December 14, 2011 - 10:13:37 PM »
I would use the 1214 FelPro pan with the blocked heat crossover , & use a paper gasket under the pan against the head to stop any oil leaks
« Reply #4 on: December 15, 2011 - 03:36:03 PM »
so paper gasket on top and bottom of the pan?
« Reply #5 on: December 15, 2011 - 09:39:58 PM »
no just below the pan
Offline dutch
« Reply #6 on: December 16, 2011 - 03:08:28 AM »
should rtv be used on either side?
*** Bart ***
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: December 16, 2011 - 09:20:23 AM »
RTV is not gasoline resistant.  Therefore it is better to use something that is.
I would use both paper gaskets if the intake bolts will still line up and can be inserted-this may not always be possible.  If not, then use one below the metal gasket as suggested.  In some cases, you may not be able to use any paper gaskets.  Be sure to use some sealant to try to prevent oil and vacuum leaks when using one, or none, paper gaskets-not rtv, however :)
