Author Topic: Electrical Drop ??  (Read 1307 times)
Offline 73440cuda
Electrical Drop ??
« on: December 16, 2011 - 11:04:08 AM »
When I turn my key to ACC, my voltage gauge reads a good 12 volts, but when I turn the key to run, it drops to about 10 volts.  Where is the division between the two as to where it gets the power from.  I would assume they would be the same path.  Think the problem may be in the switch, wiring under the dash, other?
Offline footin70rt
Re: Electrical Drop ??
« Reply #1 on: December 16, 2011 - 11:40:59 AM »
What is the voltage at the battery with the key in acc and on? Does it match the reading in the car?
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline GoodysGotaCuda
« Reply #2 on: December 16, 2011 - 04:08:25 PM »
Coil is being powered, alternator is being powered, radio, maybe the blower motor is on?, stock gauges are powered...decent little load on it. Certainly old wiring/connections won't help.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: December 16, 2011 - 05:56:30 PM »
The ignition switch. Both ccts receive their power from the same wire. Doesn't sound like a switch problem though.
Offline 73440cuda
« Reply #4 on: January 03, 2012 - 02:41:53 PM »
Readings at the battery were 11.75, and in run it was 11.50.  My voltage gauge only reads about 10.1.  I haven't started the car in a few months, so all the readings are low.  No radio, no blower, aftermarket digital gauges.  Which wire provides the power from the battery?
« Reply #5 on: January 03, 2012 - 03:14:40 PM »
Large gauge red wire comes from the battery, through the bulkhead connector to power you up. I believe that wire then goes up the steering column to the ign sw. I forget the colour of the accesories wire. Blue and brown are for the ignition start and run position.
Offline 73440cuda
« Reply #6 on: January 04, 2012 - 12:44:29 PM »
I assume you are talking about the one coming from battery to the starter relay?  Looking at the wiring diagram that goes through the firewall #16 to the ammeter.  I really dont see anything going down from the ignition switch close to the battery in the diagram.  They are very confusing.
Offline footin70rt
« Reply #7 on: January 04, 2012 - 11:01:27 PM »
The bulkhead connectors are a common problem on these cars, the male/female joint gets a little corrosion and the voltage drop just gets worse from there. This has some good info on the charging, electrical issues.
    http://madelectrical.com/electricaltech/amp-gauges.shtml
Thomas
