Author Topic: So confused been looking for hours. Power Steering Pressure Hose ??  (Read 1172 times)
Offline blown74
  • Never go less then 60 MPH in Reverse! Bel Air, Md
 :banghead: Okay so here is my dilemma. I've got a 74 challenger with a 440. Obviously not a factory combo. I have a small sector power steering box which I believe makes it a 71-72 steering box. Since I can't find all my parts I'm not sure what I'm missing. Am I suppose to have some additional fittings on the steering box side or does a hose just attached directly to it. If so what size end? Is it suppose to have an o ring or flared? Then there is the power steering pump. It's a Federal / Chrysler style pump which looks to have a pretty large fitting in the front. I have attached a picture. If only I could find the hose in the picture. Some of these hoses are over 30 inches long which is way long. What size fitting is the pump? I see a 4794 number on the hose but no luck trying to find it. Looking for any and all ideas. My head hurts from banging it on the wall in frustration. Merry Christmas everyone.   Don
American Muscle Rocks !!
Offline 4 speed fish
Re: So confused been looking for hours. Power Steering Pressure Hose ??
« Reply #1 on: December 19, 2011 - 01:06:35 AM »
Ebay item# 220913219930 email Rick he will hook you up with the correct fitting.
Offline blown74
« Reply #2 on: December 19, 2011 - 10:22:58 AM »
Thanks I will check with Rick. Which end does the O ring go on? The pump or steering box? The picture he has on the post of the hose looks nothing like the one I lost. Maybe I'm better of getting one made. However I still need to figure out what sizes and types of fittings for the ends.
« Reply #3 on: December 19, 2011 - 09:00:12 PM »
you have the older Federal type pump so a 60s application should work best , it should be flare fittings on both ends so I am not sure where the O ring would go
Offline blown74
« Reply #4 on: December 20, 2011 - 10:25:04 AM »
So does the older style federal pump work with a 72 era steering box? Obviously it does but trying to figure out the replacement cable isn't much fun. Any idea what fitting would be on that pump?
« Reply #5 on: December 20, 2011 - 04:17:15 PM »
the box is the same , there should be a flare fitting
Offline blown74
« Reply #6 on: December 22, 2011 - 02:40:01 PM »
I used a 80119 hose. Think that's an Edelmann number. 16.99 from Advance Auto Powercraft brand. The pump end was an O-ring. The steering box end I had to use a double flared end adapter to connect the the end of the hose to the steering box. It seem to work okay. No leaks so far. Merry Christmas and Happy New Year to everyone!!
« Reply #7 on: December 24, 2011 - 10:24:46 PM »
I am glad you got it sorted out  :2thumbs:
