Author Topic: Proper brake lines/master cyl/proportioning valve  (Read 816 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: December 19, 2011 - 02:01:12 AM »
<vent>I sent email off to both Fine Lines and Right Stuff Detailing parts asking about a recommendation for parts to complete my build. I sent the messages on 11/30 and never got a response. It's one of my big pet peeves about online companies. If you're going to use email as a contact method, then USE it. Now I'm actively not interested in your company.</vent>
Now I'll send the same message here.
I have a 70 Dodge Challenger that I'm putting together. It was originally a 4-wheel drum system but it now has A-body disks up front and the larger 11" (I think) drums in back. It originally was a non-powered system.
What I've purchased is the stainless lines for the rear axle and from front to rear as well as the rubber lines in front and the one in back for the rear end.
I still need the correct master cylinder, all the stainless lines, proportioning block and other pieces for the front of the car. What would you recommend to complete my system? I'm really looking for the proper parts list.
Thanks in advance.
Offline AARuFAST
  • AARuFAST
Re: Proper brake lines/master cyl/proportioning valve
« Reply #1 on: December 19, 2011 - 09:04:20 PM »
Have had a lot of luck with this company give them a call. Perfect fit lines, parts.
http://www.inlinetube.com/
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
« Reply #2 on: December 20, 2011 - 12:44:33 PM »
Inline Tube has had problems with their prop valves.  I wouldn't buy one from them.
Offline dutch
« Reply #3 on: December 20, 2011 - 12:54:15 PM »
you could try Kim @ passion for mopars.  She`s a member here. check the sales section.
*** Bart ***
