Author Topic: Was there a "headlights on" buzzer on 73s?  (Read 1173 times)
Offline Grec
« on: December 19, 2011 - 10:21:16 AM »
I came across a "headlight on buzzer" relay listed for e bodies... is my 73 Challenger supposed to have one of these?
If so, where does it go?
Thanks!
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline Jamiez
  • Retro
Re: Was there a "headlights on" buzzer on 73s?
« Reply #1 on: December 19, 2011 - 10:37:25 AM »
The relay would plug into the fuse box. The actual buzzer is next to the glovebox on the door side
Offline Grec
« Reply #2 on: December 19, 2011 - 11:46:57 AM »
Err... isn't the horn relay / key-in-ignition buzzer what's plugged into the fuse box?
- 440 Six Pack
« Reply #3 on: December 19, 2011 - 02:16:24 PM »
I'm not aware of a headlight on buzzer. The print I have for the 73's says one fuse box location is for the 'key in/horn' buzzer/relay the other is for the window lift relay.
Offline Grec
« Reply #4 on: December 19, 2011 - 02:36:02 PM »
That's what I have, too... but Jamiez is right about there being a relay / buzzer thingy attached to the dash frame next to the glovebox liner...
I don't see it in any of the schematics I have, but it's definitely there on my car. I guess I'll just have to start tracing back wires to see what it's for. :-)
- 440 Six Pack
« Reply #5 on: December 19, 2011 - 03:00:49 PM »
I think you are referring to the seat belt buzzer. I have a (disabled) seatbelt relay and buzzer by the glovebox.  :2cents:
Offline Grec
« Reply #6 on: December 19, 2011 - 06:32:47 PM »
Ahha! That's what it is. Thanks! :-)
- 440 Six Pack
Offline Jamiez
  • Retro
« Reply #7 on: December 19, 2011 - 06:39:40 PM »
Guess I didn't read closely enough. I'm not aware of a lights on buzzer,but maybe the optional lights package had that? I believe ther is only the one buzzer, even if it is triggered by multiple inputs. In my 74 the same buzzer is used for the seatbelts and the key in/door open.
I'm only aware of the fuse box relay that is shared with the horn
Offline ShelbyDogg
« Reply #8 on: December 25, 2011 - 11:02:24 AM »
On my 70 and 71s I just added a diode pigtail across one of the open, left over connectors in the main harness. The key in buzzer then works as a headlights on buzzer too, when the door is open.  I think the wiring diagrams show where to plug it in.  It was an option that came on e-bodies. One of my pigtails had a part number on it too.
Before I put this in, I used to leave my parking light on all the time.  I like to drive with my parking lights on.
Offline 72ls5fla
« Reply #9 on: December 26, 2011 - 09:56:03 PM »
hello
was wondering if you could post a pic of the diode pigtail.
It would be really helpful.
ps..  sorry for hopping into the thread
Offline ShelbyDogg
« Reply #10 on: December 26, 2011 - 10:33:22 PM »
hello
That thing is hard to see, now that my dashes are in.  It is just 2 female spade connectors with a diode between the 2 connectors, taped up with a part number on it.  Do a search on our board for headlight buzzer.  A part number comes up from a post from FY1 RT SE.  Then google that part number to see if anyone decribes it. I though it shows up in the wiring diagram. This also came up "L72 - headlight on Buzzer"
