Author Topic: How to bench test 71 Cuda rally dash tachometer  (Read 3770 times)
Offline DocMel
« on: December 19, 2011 - 10:47:21 AM »
My original tach is shot:  I have a OEM/used replacement not currently installed
How can I bench test it to see if it works?  Be advised, Im running a mallory distributor that has a tach output wire.  The OEM tach replacement I have does not work when attached to it
Any bench testing/wiring instructions are appreciated
Offline highberg
Re: How to bench test 71 Cuda rally dash tachometer
« Reply #1 on: December 19, 2011 - 09:08:00 PM »
Hook green wire to any running engine ignition coil negative lead. Hook main power wire direct to battery. Keep tach from touching metal fender, etc while hooked up. Set it on a rag. Hook it up while engine is not running so no shock.
« Last Edit: December 19, 2011 - 09:37:21 PM by highberg »
Classic Restorations
1973 Cuda 496 Stroker NOS
1971 440+6 4 Speed Roadrunner
1961 Shortbox Fleetside D100
1970 Dodge Dude 383 Auto
2009 SRT8 Challenger 6 Speed
Offline DocMel
« Reply #2 on: December 21, 2011 - 05:44:51 PM »
Thanks   EXACTLY what I was looking for   Ill give a try this weekend
« Reply #3 on: December 21, 2011 - 06:46:29 PM »
So where is the ground connection?
I don't know anything about a Mallory set-up, but the tach has to have a ground connection from somewhere.
Offline highberg
« Reply #4 on: December 21, 2011 - 08:28:10 PM »
Factory tach shouldn't require a ground. Simular to a dwell meter (which is the same concept). Aftermarket have a ground mostly to support background lighting
