Author Topic: General info on 727 to 833 swap.  (Read 3048 times)
Re: General info on 727 to 833 swop.
« Reply #15 on: January 21, 2012 - 12:45:58 PM »
there are 3 brg retainer sizes , 4.35, 4.80 , & 5.20 if it is the 5" one it is either a small block bel or a modfied big block one for use with the OD trans
Offline Sleepychallenger
« Reply #16 on: January 21, 2012 - 01:28:03 PM »
Is your 383 a HP motor? Just wondering because I wanna point out to check the back of the crank to make sure it is drilled for a 4 speed
Offline XBRIT
  • hood blackout finished
« Reply #17 on: January 22, 2012 - 06:47:02 PM »
It is a 383 motor, I am collecting all the parts and fitting the pedal box etc.. my local transmission shop will do the actual swap and he's an old school Mopar guy and aware of the input shaft to crank issue... thanks for your comments. If the Bell housing I am looking at is a 5" B/retainer and assuming a B/B can I still use it or would I have to machine a 5" to 4.8" sleeve?
« Last Edit: January 22, 2012 - 07:19:18 PM by XBRIT »
Offline zijmer
Re: General info on 727 to 833 swap.
« Reply #18 on: January 22, 2012 - 07:38:22 PM »
i think it's either a measurement mistake or it's a smallblock 833od bell housing.
Offline XBRIT
« Reply #19 on: January 22, 2012 - 08:50:48 PM »
Does this look like a big block Bell housing??
Cheers
Offline zijmer
« Reply #20 on: January 22, 2012 - 10:17:58 PM »
hi, need to see the front side. i can tell a 727 right away. if you have the housing try putting on the block. then check all the bolt holes. as far as resizing the bore it can be done but its machine shop dollars compared to the cost and availability of the right one.
Offline XBRIT
« Reply #21 on: January 22, 2012 - 10:42:23 PM »
This is the only picture from the seller.....
Offline zijmer
« Reply #22 on: January 23, 2012 - 12:08:28 AM »
from some info i have; 5.125 is 75 and newer 833od, 4.80 was for hemi and some 440's and 4.35 for every thing else
Offline XBRIT
« Reply #23 on: January 23, 2012 - 03:32:30 PM »
If it's not the correct bearing retainer size could I still mate a 833 which has a 4.8"dia retainer bearing to this 5" Bellhousing? In other words is it the bearing retainer that positions the Bell housing to the gearbox?
Cheers,
Offline zijmer
« Reply #24 on: January 23, 2012 - 06:49:46 PM »
the bearing retainer HAS TO match the bellhousing. it keeps the tranny center to the housing. you can not rely on the bolts alone. and the bearing retainers are not interchangable because they also hold the front bearing in place. the only way to use that bell housing is to take it and your bearing retainer to a machine shop and they will make a spacer to fit your retainer. you will have to way out your cost. machine shop cost verses the proper housing.
Offline XBRIT
« Reply #25 on: January 23, 2012 - 08:43:00 PM »
Yep thats what I was thinking..... Thank you for your help...
Cheers,
Offline zijmer
« Reply #26 on: January 23, 2012 - 09:42:13 PM »
i wish i had a bell housing to swap you but the shipping would kill us, i'am in calgary.  thats what i wan't to do, 451 witha 833od.
« Reply #27 on: January 24, 2012 - 11:12:24 PM »
You can machine down the 5.125 front brg retainer on a lathe to 4.80 for the std big block belhousing , it is the easiest way to match it up
Offline XBRIT
« Reply #28 on: January 29, 2012 - 04:09:14 PM »
I do appreciate everyone's help.... I think my last thing I need info on is, if the cast B.Block bell housing take either a 10.5" or 11" flywheel??  how does the starter motor work with the different diameters, it cannot engage on two different flywheel Dia's ??
Cheers,
« Reply #29 on: January 29, 2012 - 05:12:40 PM »
I believe that is a small block bel in the picture , it drops down to straight & too far on the right side for a big block .
 there are 2 belhousings & 2 flywheels , the iron bel has to be used with a 143 tooth flywheel , the alum bel is used with a 130 tooth flywheel , the only exception to this is the lakewood blastshield , it has a cup that bolts in with two optional holes for either flywheel
