Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
General info on 727 to 833 swap.
« previous
next »
Print
Pages:
1
2
3
Author
Topic: General info on 727 to 833 swap. (Read 3023 times)
XBRIT
Jr. Member
hood blackout finished
Re: General info on 727 to 833 swap.
Reply #30 on:
January 31, 2012 - 02:38:32 PM »
any one heard of a 14.5" dia X 142 tooth flywheel..... for a 440 six pack??
Logged
XBRIT
Jr. Member
Reply #31 on:
February 06, 2012 - 11:51:46 PM »
How does the different Dia flywheel use the same bellhousing and starter motor position?
Cheers,
Last Edit: February 07, 2012 - 12:05:43 AM by XBRIT
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #32 on:
February 07, 2012 - 07:54:52 PM »
As I have explained before there are 2 flywheels , 130 tooth & 143 tooth
there are also 2 belhousings , aluminum for the 130 tooth & Iron for the 143 tooth
so you need to match the components to make it work
Logged
XBRIT
Jr. Member
Reply #33 on:
February 08, 2012 - 10:32:16 PM »
okay I think I have got it... so the starter motor is bolted to the Bellhousing and not the engine block.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #34 on:
February 08, 2012 - 10:46:00 PM »
yes it is
Logged
XBRIT
Jr. Member
Reply #35 on:
February 12, 2012 - 04:01:13 PM »
Mocked up the Gearbox to bell housing, Zee Bar does not jive. The fork rod looks too close to the fork???
There are two positions for the Engine Ball stud in the Bell housing. Has anyone got a datum dimension point to chk if this will work??
Cheers,
Logged
Print
Pages:
1
2
3
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
