Author Topic: Steering column o-ring part number needed  (Read 2057 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: December 29, 2011 - 03:16:54 PM »
Hey all, I've got my column ready for assembly and all the parts are laid out and identified. I am still looking for the o-ring that goes between the firewall 2 firewall plates. My original was in good shape but is nowhere to be found (2 years and 2 moves). I'm looking for the original part number since it's likely that the dealership probably still carries these.
Any thoughts?
Thanks again.
Offline roddil
Re: Steering column o-ring part number needed
« Reply #1 on: January 23, 2013 - 06:44:36 AM »
I have this exact same question, but haven't found anything on this site.  I've also hunted the pages of the regulars like yearone, dantes, jims, etc.  Any ideas?
Offline Surfmichaels
« Reply #2 on: January 23, 2013 - 08:55:30 AM »
I have my column out right now, is it something can be found on the part itself?
Offline roddil
« Reply #3 on: January 29, 2013 - 06:26:36 AM »
There isn't a number anywhere on the oring itself that I can find.
« Reply #4 on: January 29, 2013 - 01:11:32 PM »
It might not have been on this sight but I think I remember this topic coming up before.  I don't think a dirrect replacement is available.  Mopar Muscle did a steering column rebuild article many years ago that I used when rebuilding mine.  It might have been in that article where they said a new o-ring is not available.
Offline swede-cuda
« Reply #5 on: January 29, 2013 - 02:35:13 PM »
 :wave:get a roll of vulc tape and make one.  :2cents:
« Reply #6 on: January 29, 2013 - 09:02:53 PM »
What does this O ring look like?
Any specs or dimensions?
Has anyone tried finding it from Mc Master Carr?
« Reply #7 on: January 29, 2013 - 09:45:47 PM »
There is a light taper to the outside edge but it looks easy to replace.
« Reply #8 on: January 29, 2013 - 09:47:41 PM »
Peterro, I have one here out of a scrapped column shift ? PM me your info and I'll mail it out to ya?
Offline Cuda Cody
  • Vancouver, WA
« Reply #9 on: January 29, 2013 - 09:52:31 PM »
I think about 5 years ago I got the last 2 from Mopar in the computer system.  I used them already, but I do remember buying them and thinking "dang these are going to be hard to find one day."
« Reply #10 on: January 29, 2013 - 09:57:43 PM »
So I take it that a standard O ring without the beveled edge, same size won't work?
Been tried?
« Reply #11 on: January 29, 2013 - 10:00:33 PM »
I thought the O-ring was just round...being sandwiched between the two parts for years gave it a taper.
« Reply #12 on: January 29, 2013 - 10:12:40 PM »
If you look closely at the picture you can see the light reflection is very even around the entire ring where the bevel is. Leads me to believe it was designed this way, most likely to flatten out evenly under pressure or because that part happened to be produced already so it was cheaper. Either way I would feel fine replacing mine with a standard o ring.
Offline Cuda Cody
  • Vancouver, WA
« Reply #13 on: January 29, 2013 - 10:57:59 PM »
They were originally round, not tapered or beveled.  Any "O" ring the same size should work just fine.
« Reply #14 on: January 30, 2013 - 07:01:32 AM »
The one I have is not round anymore? Make scence though Cody. I'm sure you could go to a hydraulic supply and get an o ring that's very close?
