Author Topic: Rear floor pan extension to crossmember  (Read 2943 times)
Offline ourname
« on: January 02, 2012 - 12:18:48 AM »
Does anyone have a picture of the installation of this piece. It seems to me that it is too long. When I install the floor pan extension the crossmember extension does not fit.
Options? Do I cut to fit?
1966 Charger
1974 Cuda
2005 Daytona
2012 Ram 1500 Sport
Offline ourname
Re: Rear floor pan extension to crossmember
« Reply #1 on: January 02, 2012 - 12:22:35 AM »
Better picture
1966 Charger
1974 Cuda
2005 Daytona
2012 Ram 1500 Sport
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: January 02, 2012 - 11:49:18 AM »
here you go, NO CUTTING
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: January 02, 2012 - 11:50:58 AM »
overlaps from the back side and this is where the adjustment comes in for the drop off.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline ourname
« Reply #4 on: January 02, 2012 - 09:14:09 PM »
Thanks.  I would expect I should install after the rear quarters and tail light panel is installed. Then it would be a perfect fit.
1966 Charger
1974 Cuda
2005 Daytona
2012 Ram 1500 Sport
Offline 1970RTSE
« Reply #5 on: January 05, 2012 - 12:22:59 PM »
You actually want to install it along with the trunk extension.  That piece gets spot welled to the rear cross member and the flange gets a couple of spot welds on the trunk extension.  If you install the quarter and trunk extension, you will be trying to plug weld up between the extension and the frame rail  Its possible, but just tight.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #6 on: January 06, 2012 - 05:37:27 PM »
look at the rusty pic and yours, it almost looks like you may have installed the rear x member backawards ? THE TOP FLANGE faces out,
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #7 on: January 06, 2012 - 05:47:47 PM »
in the above pic you'll see the top flange out, the bottom in. this is the original to the car and wasnt changed.
in the rusty pic you can make out the end of the crossmember bends inward,
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline ourname
« Reply #8 on: January 23, 2012 - 11:38:09 PM »
My picture may have been poor. I have the top flange out. The pictures you have supplied have helped me.
Thanks
1966 Charger
1974 Cuda
2005 Daytona
2012 Ram 1500 Sport
Offline jimynick
« Reply #9 on: January 24, 2012 - 10:52:03 PM »
I'm just at the stage where I'm putting my extension in and it seems that they were a "slide it over until it fits" part. The upper flange goes over the rear crossmember and under the trunk floor and the lower one goes on top of the crossmember flange. I'm not going to weld mine to the crossmember until I have both 1/4's fitted with the rear valance in place to mark their final set, because the extension controls how much the trunk extensions can move, which affects the 1/4 to valance fitting. The knee bone IS connected to the shinbone!  :2cents:
Offline ourname
« Reply #10 on: January 25, 2012 - 11:21:07 PM »
I agree.....
I am just ready to slide them into the "fit" spot.  I have installed my lower valence and set the gaps. I am happy with the fit and will now install the extensions.
I think I will glue the outside of the extensions to the inner quarter. It will be tough but not impossible to weld.
1966 Charger
1974 Cuda
2005 Daytona
2012 Ram 1500 Sport
Offline ourname
« Reply #11 on: January 28, 2012 - 06:49:36 PM »
Here is my completed extensions. I have to grind and prep it.
1966 Charger
1974 Cuda
2005 Daytona
2012 Ram 1500 Sport
