Author Topic: Slapstick with reverse valve body  (Read 3221 times)
Offline burnoutking-1
« on: January 03, 2012 - 05:13:57 PM »
Putting a full manual reverse valve body with trans brake into my challenger.  Just wondering if there is anyway to get the slapstick shifter to work the opposite way or would I have to get an aftermarket shifter?
Thanks.
Re: Slapstick with reverse valve body
« Reply #1 on: January 03, 2012 - 09:12:50 PM »
There is an aftrmarket plate that you can install that reverses the stock slap-stick.  I'd have to do a search to find it.  I think there has been mixed results with it though.  I don't think it is as smooth as the stock one is.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #2 on: January 03, 2012 - 09:50:17 PM »
As far as aftermarket shifter, I think 72challorange sold a shifter that was a reverse manual pattern last year.  Forget what brand it was...began with "R" I think.... can't remember the name!!!  :banghead:
« Reply #3 on: January 03, 2012 - 09:55:10 PM »
Ok, found it: "Duncan Motor Sports Shift-R-Arm with optional Pistol grip attachment  perfect for Reverse Manual valve Body"
http://www.cuda-challenger.com/cc/index.php?topic=54512.0
http://www.duncan-motor-sports.com/prod02.htm
Offline 74challenger03
« Reply #4 on: January 18, 2012 - 07:56:33 PM »
nice shifter but $300+shipping for the e-bodie with pistol grip. come on that a joke right?
« Reply #5 on: January 18, 2012 - 08:48:09 PM »
I myself usually just modify my slapstick for a Reverse manual vb.  You just file down the second gear notch. I am doing this to Cudaguys project now :2thumbs:You slap it from first to second, push the button in for 3rd. Still maintains revers lock out.
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #6 on: January 18, 2012 - 09:21:42 PM »
That price ($300 bucks) is for the shifter arm and the shifter kit which is called the "Shift-R-Gate" which is also made by Ducan Motor Sports and it's only $30 bucks. I use one and it works fine. If you only want the kit for your shifter then you don't have to spend $300 bucks. See link below!  :2thumbs:
http://www.duncan-motor-sports.com/prod01.htm
        Matt B.
Matt
« Reply #7 on: January 18, 2012 - 09:29:44 PM »
That's more like it. I figured there had to be some way to make it work.
« Reply #8 on: January 20, 2012 - 05:41:26 PM »
Hey,  look what I found.........
https://www.coperacingtrans.com/product_info.php?cPath=23&products_id=311&osCsid=86cf2ab9b561b376f7bc21fef0d0af7c
« Reply #9 on: January 20, 2012 - 06:09:23 PM »
Yeah, I know about that plate from Copes.  I just like free and simple to do is all. Still 45.00 is a good deal I guess if you wanted to do a conversion. Once done, easy on and off.
« Reply #10 on: January 20, 2012 - 06:29:59 PM »
I was just kinda surprised, because any other kind of plate I had seen was ridiculously priced.  I too like the free do it yourself. But cheap enough, that it would be worth it just in case you ever needed to get it to original again.
« Reply #11 on: January 21, 2012 - 06:21:19 PM »
And it's even cheaper than $45 bucks. It's only $30 bucks!! For that much, I just bought it & I'm a tight wad!! :roflsmiley:
        Matt B.
Matt
