Author Topic: 5 Bow Headliner Install - Problems - Picts Enclosed  (Read 1095 times)
Offline FRSHFSH
« on: January 06, 2012 - 08:38:25 AM »
I am in the process of installing a 5 bow headliner in my 70 cuda.  It was orignally a grand coupe and i bought the five rod set up with the clips online.
Bows #1 thru 4 fit great (Front two before the dome light, and two behind the dome light).  The fifth (one by back glass) seems to be too big.
Doing a search on this forum someone posted that the rod lengths were 51-1/4" #1 thru 4, 54-1/4" #5 bow.  The fifth bow i have measures about 54", so it leaves me with the following questions:
-Do i have the clips in the wrong place?
-Did i get the wrong 5th bow?
-Cause the body is a grand coupe, do i have to modify something to fit?
Anyone's and everyones help is greatly appreciated.
"We will remodel the house once the cuda is finished"
Offline challengermaniac
Re: 5 Bow Headliner Install - Problems - Picts Enclosed
« Reply #1 on: January 06, 2012 - 11:18:31 AM »
Please be sure to do a "headliner" search on here for all of the prior posts on this subject.  I don't have any specific knowledge regarding the Grand Coupe (others likely do), but if the 5th bow does not fit between the clips, I would think you could evenly grind it down to fit. If on the other hand you are finding that the headliner it's self does not fit, that would be due to the sleeves on the aftermarket liners are too long and you just need to snip (very carefully) a slit about 3/4" in to free the bow sooner.  Once you have the 5th bow in place, the whole idea is to square up the liner and then attached it at the front windshild area, stretch & attach it to the back window and then streatch and attach it at the sides, being sure to keep your corner points square.  Hopefully, you considered installing a sound deadner such as FatMat along with insulation (the thick carpet insulation works great), prior to installing the headliner.  Best!
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
