Author Topic: Which headers for clearance?  (Read 1872 times)
Offline RCCDrew
« on: January 07, 2012 - 12:20:11 AM »
My 340 hedman headers are the lowest part of my car. Lately they have been kissing speed bumps. What kind of headers should I switch to to get some clearance?
Re: Which headers for clearance?
« Reply #1 on: January 07, 2012 - 01:21:46 AM »
from worst to best
Hooker  5115
Dougs
TTI
 these are the only three that stay above the steering
Offline Sonnythebull
« Reply #2 on: January 07, 2012 - 09:30:24 AM »
 :rebel:
from worst to best
Hooker  5115
Dougs
TTI
Tti touch steering box and torsion bar on my challenger. Still trying to figure out a way to bend adjust etc
Offline mojavered
  • Someday!
« Reply #3 on: January 07, 2012 - 11:43:47 AM »
:rebel:
possibly engine mounts?
Jason
« Reply #4 on: January 07, 2012 - 01:57:27 PM »
 :wave:
Seems to be a common issue with headers. Engine even has a strap stopping it from torquing to much under load. Spring time we will heat me up and do some bending. The clearance issue is very minor but annoying
« Reply #5 on: January 07, 2012 - 02:13:42 PM »
Try an 1/8" shim on the motor mount. You'd be surprised what an 1/8" shim will do!  :2thumbs:
You think yours is a challenge.... try a 440! :grinyes:
Offline RCCDrew
« Reply #6 on: January 09, 2012 - 01:39:03 AM »
How about block huggers? Anyone use them?
Offline RCCDrew
« Reply #7 on: January 09, 2012 - 01:57:05 AM »
Also, will magnum headers fit an la engine? I remembered I have a nice
Set of those lying around.
« Reply #8 on: January 09, 2012 - 08:53:40 AM »
Magnum manfolds work fine
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #9 on: January 09, 2012 - 09:39:08 AM »
I am running Doug's headers on my Challenger with power steering and they were the easiest headers to install I have ever done, no fitment issues what so ever, they just went right in. It should be noted though I am running a high torque mini starter, so not sure about stock starter clearance.
1996 Dodge Viper GTS Coupe
Offline RCCDrew
« Reply #10 on: January 09, 2012 - 07:50:09 PM »
How is the ground clearance? My headers hang way below my oil pan and k member.
Offline RCCDrew
« Reply #11 on: January 09, 2012 - 07:51:31 PM »
I actually have some coated headers. No miles and really nice. I will check those out.
Offline RCCDrew
« Reply #12 on: January 25, 2012 - 08:22:48 AM »
Well the coated headers I have are for a truck, so no good. Tti are pricey. I'll check Doug's.
