Author Topic: What are the holes in this picture for?  (Read 1532 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: January 07, 2012 - 07:38:17 PM »
I was working in the trunk for the fuel filler and noticed these holes below the screwdriver. I have no memory of what they're for. Any thoughts/pictures?
Thanks
Offline Cooter
    • christinecarclub.com
Re: What are the holes in this picture for?
« Reply #1 on: January 07, 2012 - 07:49:27 PM »
Not sure but Mine had the exhaust resonator hanger bolted through those holes.
Offline peterro
    • The Pistonhead
« Reply #2 on: January 07, 2012 - 07:53:20 PM »
That's right. I ran across that part recently and couldn't remember what it was for but it looked familiar.
Thanks a lot.
Offline spamtank
« Reply #3 on: January 07, 2012 - 08:00:02 PM »
Thanks
Just checked mine.
Those are tail pipe hangers bracket hole.
Should have another set on the other side.
Rick
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline peterro
    • The Pistonhead
« Reply #4 on: January 08, 2012 - 08:59:58 PM »
Well the spot is on the other side but there are no holes. May have to make some when I get around to the exhaust.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #5 on: January 08, 2012 - 11:00:08 PM »
Did you have the trunk pan replaced on that side before?  Do the replacements come with holes?  :clueless:
« Reply #6 on: January 08, 2012 - 11:05:44 PM »
no they do not. No holes at all in the trunk floors.
U drill DIY what one's you want.
Offline peterro
    • The Pistonhead
« Reply #7 on: January 08, 2012 - 11:10:18 PM »
Nope the floor wasn't replaced. It was a 318 car so it probably originally had a single exhaust.
« Reply #8 on: January 08, 2012 - 11:16:35 PM »
That was my second thought but it looked like your car was an R/T....
Offline peterro
    • The Pistonhead
« Reply #9 on: January 09, 2012 - 12:51:06 AM »
Heh, that's the idea.   :naughty:
« Reply #10 on: January 09, 2012 - 12:57:09 AM »
If your car was a 318, then it should've had at least 2 holes on the passenger side in the trunk for the bracket.
Regardless of the eshaust system it came with.
Offline peterro
    • The Pistonhead
« Reply #11 on: January 09, 2012 - 01:24:19 AM »
It does. It's the drivers side that are not there, at least for now.
« Reply #12 on: January 09, 2012 - 07:51:07 PM »
I disagee , the slant 6 car had the exhaust on the left only so no holes in the passengerside
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« Reply #13 on: January 09, 2012 - 08:40:43 PM »
I agree .... my car was originally a 318 car .... holes on the right only and the stampings for the other holes I believe were there.   We just drilled them out .... same location, but on the driver side.   Now have plates on both sides to hand the tail pipes (without resonators).
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
« Reply #14 on: January 09, 2012 - 08:54:26 PM »
 :iagree: same here....mine was a /6 car originally
