Author Topic: Charger won't start  (Read 2451 times)
Offline Sleepychallenger
Charger won't start
« on: January 08, 2012 - 12:28:47 AM »
Ok guys and gals, my buddy here just put an MSD coil and distributed in his 69 charger. It started for a couple days but would not start after being driven and getting hot. Now the car won't start at all. It is getting air and fuel but we can't find spark. With the key in the on position the coil has power to both sides which seemed odd to me. The guys at MSD told him to bypass the ballast resister and put the wires together. Can anyone help me out and give me some steps to try and help him out. He also made the plug wires too. Thanks everyone
Drew (sleepy)
Offline GranCuda1970
Re: Charger won't start
« Reply #1 on: January 08, 2012 - 12:34:33 AM »
The how to - was in the month before lasts mopar muscle magazine but I think that was for a stock set-up if I remember right.
« Last Edit: January 08, 2012 - 12:58:27 AM by GranCuda1970 »
« Reply #2 on: January 08, 2012 - 12:42:30 AM »
« Reply #3 on: January 08, 2012 - 12:47:11 AM »
If the unit is new he can get a RMA # and return it for a new unit.
« Reply #4 on: January 08, 2012 - 01:29:58 AM »
He sent the unit back and they said that the dust and coil tested just fine. If the manual suggest using the ballast I wonder why the tech line said to bypass it. They even said to put the two wires from the one side of the ballast and just twist them together and splice them to the wires from the other side of the ballast.
« Reply #5 on: January 08, 2012 - 01:36:21 AM »
 :clueless:
« Reply #6 on: January 08, 2012 - 01:48:22 AM »
« Last Edit: January 08, 2012 - 01:51:52 AM by GranCuda1970 »
« Reply #7 on: January 08, 2012 - 01:54:18 AM »
I read solid core plug wires cannot be used with a MSD ignition system.
http://www.pirate4x4.com/tech/billavista/PDFs/MSD%20Ignition%207al-2.pdf
« Last Edit: January 08, 2012 - 01:55:54 AM by GranCuda1970 »
« Reply #8 on: January 08, 2012 - 02:01:24 AM »
On the  oil trouble shooting link it said I won't have 12v at the coil + but I do...
« Reply #9 on: January 08, 2012 - 02:01:42 AM »
Sometimes a ground strap off of the coil directly to the firewall cures this issue.
off another forum.
 Make sure you have:
1. Good battery, more important good grounding with the negative term and engine block.
2. Good 12 Volts to the coil. If this is the electronic dist set up, ditch the ceramics.
3. Hook the wires up as directed. Mine was black to ground, red to hot side of coil and orange to negative side. It also needed to use the hook up kit that came with the dist.
4. Recheck your spark with key on, coil wire out should be 12volts.
5. Ensure timing is on so things will come to life.
Sounds like you have that.  :clueless:
« Last Edit: January 08, 2012 - 02:09:42 AM by GranCuda1970 »
« Reply #10 on: January 08, 2012 - 02:09:28 AM »
I did check all of his grounds and also ensured that thee was a ground from the cool to the firewall
« Reply #11 on: January 08, 2012 - 02:23:40 AM »
Making sure the engine was properly timed something about the ingnition only generating spark for 20deg of turn. Making sure you have a new cap and rotor. Unplug the spark plug wires and replug them. Swaping coil with another coil if you have it and testing.
« Reply #12 on: January 08, 2012 - 02:40:23 AM »
Sounds like a common problem Hope you get her figured out !!
« Reply #13 on: January 08, 2012 - 03:56:35 AM »
I will keep everyone posted with the trials and errors
« Reply #14 on: January 08, 2012 - 04:01:04 AM »
Just thought of this, he doesn't have to have a box like the 6al or anything does he? I think he is running just the MSD coil and dist
