Author Topic: help with green bearings  (Read 4496 times)
Offline Jamie
« on: January 08, 2012 - 05:07:00 PM »
Ok ,I need some help! I am assembling my 8 3/4. i bought a green bearing kit and a disc brake conversion kit. When I pressed the new bearings onto axle shaft I am not getting them to push all the way onto axle.I have a 1/4 difference exactly on both axles and this makes them sit further out of axle housing. I have lots of experience with pressing things like this and both of the bearings stop at the same distance??????  I can see a 1/4" line where the old bearings sat but with a different style bearing ,I thought this may be normal but not the case because I cannot get the calipers on now. If I cannot get the bearings any further in then I guess I could machine down the spacers on the caliper bracket. And as usual no instructions with bearing kit. Any help would be awesome.
I will finish a project.I will finish a project. I will finish a project.
70 barracuda plum crazy
( current goal is to keep just one car) AND FINISH IT!
08 charger r/t  w/road & track package
2011 silverado
Re: help with green bearings
« Reply #1 on: January 08, 2012 - 05:28:45 PM »
Welcome to the pitfalls of green brgs !!
 you need to remove the spacer inside the diff or trim down the axle length to fittheaxles all the way in , this can also upset the brake aligment with the axles in futher than stock as you are finding out , Another reason why I use stock brgs  :pullinghair:
Offline Jamie
« Reply #2 on: January 08, 2012 - 07:47:36 PM »
Actually it seems like the bearing itself just won't slide all the way onto the shaft. I have a stock rear and the measurement fromflange to flange is a half inch wider on the rear I am doing. I feel that it is all about the bearing placement, the only reason I bought the bearing kit was because brake kit said it was mandatory!
2011 silverado
Offline jimynick
« Reply #3 on: January 08, 2012 - 11:51:43 PM »
Jamie, I can't speak for you, but I'd take those green bearings off and either take a brake cylinder hone to the inr race or some sand paper to the axle until I got them on. I'd also suggest throwing the axles in the freezer for a couple of hours and the bearings in a 200' oven for 15 minutes before I tried to put them on again. It sounds like you only need a couple of thou to get there. Don't forget a dab of good, high pressure lubricant as well. Good luck.  :thumbsup:
Offline Cooter
    • christinecarclub.com
« Reply #4 on: January 09, 2012 - 01:24:08 AM »
Rear disc brakes ain't worth all that.
Offline 72cudamaan
« Reply #5 on: January 09, 2012 - 08:22:04 AM »
I bet they are to Jamie.  ;D
If I cant fix it, it's broke
Andy  (phukker whither)
Offline footin70rt
« Reply #6 on: January 09, 2012 - 10:27:33 AM »
I did a disc conversion on the rear of a 69 Road Runner and we ended up just machining a little off the end of the axle. If I remember right it was just the taper before the splines that had to be removed.
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline Cooter
« Reply #7 on: January 09, 2012 - 12:43:34 PM »
Aren't these the same bearings that only last about a year after all this trouble??
I think I read some horror stories about Green bearings giving up when sided loaded.
« Reply #8 on: January 09, 2012 - 02:22:22 PM »
 Yep... they didn't last one night in a stock car ( racecar) :puke:   Stock tapered last for years! :2thumbs:
Offline jhaag
« Reply #9 on: January 09, 2012 - 06:10:42 PM »
So with all the bad press on this site concerning the green bearings, what is the solution for those who want to run rear discs? Does anyone make a kit for the stock tapered bearings?
love 70 Challengers
« Reply #10 on: January 09, 2012 - 06:34:46 PM »
Why can't you use the stock style bearings with rear disc brakes? I didn't know that? :clueless:
« Reply #11 on: January 09, 2012 - 07:59:39 PM »
the plate to support the caliper has to bolt on to the flange studs so you have to replace the retainer plate & lose the adjustment to mount the caliper bracket , the system I install from SsBC worked without replacing the retainer plate so you could use the stock brg but the caliper was too wide & hit the rear sway bar  :banghead:
« Reply #12 on: January 09, 2012 - 08:12:37 PM »
Hummm good to know! I'll have to ask Cass about this and see what he offers.( Still planning a Dana 60) I'm not willing to give up the tapered bearings for disc brakes.
« Reply #13 on: January 09, 2012 - 09:00:08 PM »
I agree , the tapered brg is afr superior but you can use longer studs to hold the caliper bracket & pinch the stock adjuster
« Reply #14 on: January 09, 2012 - 09:08:47 PM »
I'll look into the SSBC set up too. I have the Hotchkis rear sway bar so it may clear for me?
