Author Topic: Found these in a 8 3/4 housing.... clues anyone?  (Read 1409 times)
Offline footin70rt
« on: January 09, 2012 - 06:34:40 PM »
Pulled the chunk out of a friends 67 GTX today and found these 2 little pieces laying in the bottom of the housing.  :dunno: Has a 741 chunk with 3.91 suregrip. This car has been sitting for over 20 years so we are just going through checking things out before we put the engine and trans back in. The one has a roll pin sticking out. Thanks for your help.
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Re: Found these in a 8 3/4 housing.... clues anyone?
« Reply #1 on: January 09, 2012 - 08:02:03 PM »
With the clutch type sure grip they used those buttons in the center pin to allow the end play adjustment , the roll pin is supposed to hold them together long enough to install the axles
Offline footin70rt
« Reply #2 on: January 09, 2012 - 08:24:10 PM »
Thanks Chryco! I've only had a 489 apart and was at a loss to where these things came from. Any tips to make sure they stay in place during reassembly?
Thomas
« Reply #3 on: January 09, 2012 - 08:57:52 PM »
Try spreading the roll pin so it is tight or use Grease , you can see then looking down the tube with a strong light to be sure they stayed in place
Offline footin70rt
« Reply #4 on: January 10, 2012 - 01:13:42 AM »
I gooped em up good with transgel. Worked perfectly. Thanks again!   :2thumbs:
Thomas
Offline VPOINTCUDA
  • Wish she were done so I could take her out Ridin!
« Reply #5 on: January 22, 2012 - 02:34:40 PM »
I had to remove my axles to have the wheel studs repaired, and found the same thing. Chryco, did these come on the 1970 and newer differentials or only on the older ones? I know that the rear in my '73 Cuda was donored before I got it, but haven't got a clue from what year or what type of vehicle.
" the question isn't  when is he going to stop, but whose gonna stop him!"
« Reply #6 on: January 24, 2012 - 11:10:24 PM »
the buttons were used n the clutch type sure grips which after this many years could be in any year car
