Author Topic: Shaker dash cable routing with Air Conditioning using Sanden Compressor??  (Read 2283 times)
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
I know that the factory didn't mix A/C with a Shaker set up, so I may be asking the impossible, but hope not.   I need to know if anyone else out there has done this successfully?   If so, how did you route the CARB AIR cable through the firewall.  Thoughts??  If possible PICS would be great.   I am fussing with where to drill out the firewall .... uggh.
I am planning to run a SANDEN compressor down low when it comes time to plumb in the A/C (not this year probably).
Thanks in advance for your feedback .... CHAPS!
« Last Edit: January 23, 2012 - 04:34:15 PM by chaps70rt »
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Re: shaker dash cable routing with Air Conditioning??
« Reply #1 on: January 09, 2012 - 11:36:23 PM »
Hole.
Offline chaps70rt
« Reply #2 on: January 11, 2012 - 10:19:27 PM »
Sorry Topcat ..... I should have rephrased that.   I realize that it is a hole, but need to know where on the firewall.  Do you have another pic you could post that shows exactly where you brought it through?   I am presuming you have A/C ...... and that the cable is in the stock location?
Thanks again ..... CHAPS
440 - 4BBL - Shaker
« Reply #3 on: January 12, 2012 - 01:01:40 AM »
I don't have any pics of an A/C car that was a shaker with A/C. Ever seen that?
That picture is the exact location the factory did. Use that as your best judgement where it should be.
Or maybe someone here can reply...
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: January 12, 2012 - 01:33:31 PM »
they never made an E body with a shaker with AC, the compressor would be in the way.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #5 on: January 12, 2012 - 11:58:32 PM »
I know that Dave...a touch of sarcasm was what I was getting at.
Offline chaps70rt
« Reply #6 on: January 16, 2012 - 10:47:32 PM »
Guys .... as originally stated, I know that the factory didn't mix these two.   I was hoping to find out from those that have added it, where it best fits with the larger Heater box, etc .....   Just thought I should clarify.   Hoping someone has been successful in making this work???
I may have to wing it I guess?   Thanks ..... CHAPS
440 - 4BBL - Shaker
Offline chaps70rt
« Reply #7 on: January 18, 2012 - 10:40:51 PM »
Hey Topcat .... what else runs inside the same hole along with the shaker cable in your picture??  Is it an accessory or reverse light wire perhaps?   An added wire for something non standard?
Thanks ... CHAPS
440 - 4BBL - Shaker
« Reply #8 on: January 18, 2012 - 11:19:43 PM »
Thanks ... CHAPS
That's a 71' only picture of a Shaker.
In 71', they had a manual choke on Hemi's. So it had an additional cable running thru the same grommet.
Offline chaps70rt
« Reply #9 on: January 19, 2012 - 10:55:42 PM »
OKay .... great.   Thanks for clarifying.    Seems that there are no others out there that have done or are planning to do what I am up to ...... shaker and a/c (using Sanden ..... not original Mopar compressor)!!   Maybe I am nuts for going down this path ..... but nothing ventured nothing gained.
Cheers ..... CHAPS
440 - 4BBL - Shaker
