Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
wire locations thru firewall
« previous
next »
Print
Pages: [
1
Author
Topic: wire locations thru firewall (Read 3779 times)
dougs bs23
Sr. Member
on:
January 10, 2012 - 01:26:01 PM »
Looking at the firewall pics from another post on here, i see on an ac firewall where the vacuum line for the heaterbox comes thru the wall, so, where does the electrical connections for the blower motor and low pressure switch come thru the wall? or is it through the same hole as the vacuum line? help
Logged
see Bill run go Navy football///fly navy
74challenger03
Full Member
Re: wire locations thru firewall
Reply #1 on:
January 21, 2012 - 08:13:43 AM »
i believe it is on your wiring harness thats were my wire for my blower motor comes from.
Logged
Katfish
Resident
70 Challenger
Reply #2 on:
January 21, 2012 - 08:26:23 AM »
This might help
Logged
TinCuda
Sr. Member
Reply #3 on:
January 21, 2012 - 08:27:20 AM »
I this the picture that you are talking about?
Logged
(O O [ SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Shot at 2012-09-05
74challenger03
Full Member
Reply #4 on:
March 21, 2012 - 01:47:03 PM »
were is hole for ac/heater temp cable?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
March 22, 2012 - 10:18:52 AM »
it may come through the Manual washer pump hole as I recall
Logged
FY1Cuda
Sr. Member
Reply #6 on:
March 22, 2012 - 05:05:29 PM »
Our cable goes through the AC vacuum hole shown in the first photo. I don't know if it's correct, but it works.
Logged
74challenger03
Full Member
Reply #7 on:
March 22, 2012 - 07:54:53 PM »
your cable must turn hard under the dash were it hooks up to the controls.If it works then i guess i will give it a try. thanks
Logged
TinCuda
Sr. Member
Reply #8 on:
March 22, 2012 - 09:52:56 PM »
Sorry that I didn't have much time to look on the way to work, but I did pop my hood. Mine looks like it comes out somewhere behind the brake master cylinder booster. Then it runs across the fire wall, on the engine side, to the valve.
Logged
(O O [ SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
74challenger03
Full Member
Reply #9 on:
March 24, 2012 - 04:29:53 PM »
installed new cable but the cable turns hard when running it from next to the booster.It bent my cable so im at a lost.
Logged
swede-cuda
Jr. Member
Reply #10 on:
March 26, 2012 - 03:11:47 PM »
you have a 73? did you route it through the hole marked insulation retainers,below the lower clutch bracket hole as in the pic of the green firewall pic? i bet its a sharp turn but i think the turn it makes when going for the hole by the blower motor is tighter.ive got the near the blower motor grommet with 2 holes on my car so ive only routed that way,and its sharp.make sure your cable is oiled and take your time routing it the best way.im talking about the cable routing for the water valve
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
