Author Topic: Anyone ever successfully disassembled a bumper jack assembly?  (Read 962 times)
Offline Grec
« on: January 10, 2012 - 02:42:51 PM »
I'm looking to refinish my jack but when I took a good look at it, it became apparent that these things were not meant to be taken apart. ie, the metal stops pressed into the mast to prevent the actual jack assembly from coming off, etc.
I suppose it could be blasted as an assembly and repainted (PITA) but it'd definitely be better to take it apart.
Anyone have any ideas / tips?
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: Anyone ever successfully disassembled a bumper jack assembly?
« Reply #1 on: January 10, 2012 - 03:14:25 PM »
Most people just mask/repaint everything while it's still together.  I have heard of people spreading the mechanism open enough to remove it from the shaft.
Offline Grec
« Reply #2 on: January 10, 2012 - 06:49:23 PM »
Hmmm... Sounds like a job for my giant-sized flat head screwdriver. :-)
- 440 Six Pack
« Reply #3 on: January 10, 2012 - 07:56:04 PM »
Have you found a gray paint that matches the original color?  Rustoleum Dove Gray used to be the color of choise but it has been discontinued.  Totally Auto sells jack paint but it's expensive.
Offline 71340RT
« Reply #4 on: January 11, 2012 - 01:04:24 AM »
Krylon discontinued there dove gray too. Krylon does have 3551 classic gray which is close and I have used it for my jack.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
« Reply #5 on: January 11, 2012 - 09:54:40 AM »
Maybe it was Krylon and not Rustoleum.  I havn't heard of a good cheap replacement yet.  If you are doing multiple jacks, I can see spending the money on the Totally Auto paint.  If you're just doing one, it's kind of hard to spend $25 plus shipping.
I thought about just using primer and spraying a gloss clear over it.  I know every manufacturer has a slightly different shade of primer.
Offline Grec
« Reply #6 on: January 11, 2012 - 12:38:35 PM »
I googled Rustoleum Dove Gray the other day and it showed that Grainger industrial supply sells it. I called them and they seemed to think they had it, just not in my local store. They said they could ship it to the store in my town.
I'll let you know if I'm able to get it.
www.grainger.com
- 440 Six Pack
