Author Topic: Front sway bar: Pointed up or pointed down?  (Read 898 times)
Offline Grec
« on: January 10, 2012 - 11:23:57 PM »
Ugh.
I actually read a thread about this a loooong time ago but forget the answer.
Which way do the front sway bars mount?
There is a slight vertical / Y axis curve on the ends. Question is... when installed, should the curve go up or down?
Definitely a d'oh! moment for me when I realized I had no way of telling after pulling it out of the car and changing the orientation of the bushings. :-)
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline PlumCraZRT
Re: Front sway bar: Pointed up or pointed down?
« Reply #1 on: January 11, 2012 - 02:00:47 AM »
I'm not sure I know the answer, but when you install it, only one way will have the ends of the bar parallel (or more parllel)  to the ground.
You should only need to mock it up next to the car to figure it out.  :thumbsup:
mmmmm.... Mopar.... *drool*
« Reply #2 on: January 11, 2012 - 08:45:27 AM »
As someone here pointed out I posted both ways as being correct so now I am not sure again !!
« Reply #3 on: January 11, 2012 - 09:58:00 AM »
I've got a picture of mine that shows which way the bar was facing originally.  I'll have to look for it.  I'm sure it was possible that some cars had there's installed the wrong way.  It will work either way...it just fits better one way vers the other.
Offline Grec
« Reply #4 on: January 11, 2012 - 12:47:20 PM »
And that's what I remember from reading the original post way back when... There didn't seem to be a consensus. Lol.
I really need to get into the habit of photographic EVERYTHING with my phone before I take it apart. I'm usually pretty good about it, but this seemed so straight forward it never occurred to me. Lesson learned. Again. :-)
If you can find that pic Burdar, I'd appreciate it. Not only that, we can finally have a more definitive answer on this particular question. :-)
- 440 Six Pack
Offline GranCuda1970
« Reply #5 on: January 11, 2012 - 12:50:26 PM »
I think I installed mine UP now I am not sure I have to go look now!!  :clueless:
« Reply #6 on: January 11, 2012 - 01:03:14 PM »
The bar crowns up.  That means the end of the bar points down.
Offline Grec
« Reply #7 on: January 11, 2012 - 01:49:42 PM »
That would seem to be the case.
I can actually make out the slight bend in the bar from that pic. Down it is.
Thanks, bud.
- 440 Six Pack
