Author Topic: 70 rocker panel question  (Read 1564 times)
Offline Jocigar
« on: January 11, 2012 - 10:59:51 AM »
the trim piece that mounts to rocker panel. (looks like gills)
whats it called and what that part a coded option for 70 cuda
Thanks
Offline aarcuda33
Re: 70 rocker panel question
« Reply #1 on: January 11, 2012 - 11:13:38 AM »
 If you are refering to a 1970 cuda they are called fish gill rockers and I believe they were an option. If you are looking to buy a set be aware that there is a right side and a left side on these
Offline kissalien
« Reply #2 on: January 11, 2012 - 11:15:08 AM »
M25 - Custom Sill Moldings. They were standard on 'Cuda and Gran Coupe though only the 'Cuda ones looked like gills. They were not available on the Barracuda or the AAR 'Cuda.
Offline Jocigar
« Reply #3 on: January 11, 2012 - 12:40:46 PM »
Thanks, I found what looks to be pre-drilled holes on the front of rear quarter... not sure if their placement is correct for this molding.
I dont remember seeing a ref on the fender tag.  :clueless:   I'll have another look
THanks  :cheers:
Offline Jocigar
« Reply #4 on: January 12, 2012 - 09:52:28 PM »
Ok.   I took a look at the tag and the code m25 is on third line.   The decode was wide sill moulding (1/2 molding along top edge of doors).  Is that right?   I also have m88
Thx
Offline kissalien
« Reply #5 on: January 13, 2012 - 09:46:44 AM »
Thx
Moldings at the top of the door are called belt moldings because they are at the belt line of the car. (Like how your belt would be at the middle of you.) I think those are M31, but I'd have to look it up.
All Cudas have M88. It's the trim around the rear panel.
Offline swede-cuda
« Reply #6 on: January 14, 2012 - 12:56:44 PM »
 :wave: if your car is a 70 cuda,then it should have the fish gill moldings.9 holes on each side of the car.  :bigsmile:
