Author Topic: How to replace rear springs  (Read 3569 times)
Offline Aracer
Re: How to replace rear springs
« Reply #15 on: January 22, 2012 - 01:13:42 AM »
     For adjustments later on, another trick is to tap out the front hangar studs, to let the spring hangar drop down towards the floor. I do this to change the 5/8" bolt position, or change hangars. The leafs can stay attached to the axle housing for this adjustment.
     The front hangar, u bolts, then the rear shackles will come out, so the valance stays put.
« Last Edit: January 23, 2012 - 07:41:33 PM by Aracer »
Offline ff6849
« Reply #16 on: January 22, 2012 - 06:52:19 AM »
To spamtank:
I am still waiting for everything to arrive,  hopefully everything will be here Wednesday  or Thursday from espo, I will keep all posted
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
