Author Topic: 72-4 Shell  (Read 3204 times)
Offline TreeFrog
    • TreeFrog
72-4 Shell
« on: January 14, 2012 - 09:13:12 PM »
If you were to stip a 72, 73 & 74 to the last bolt ....
how many differences are there unibody-shell to unibody-shell?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: 72-4 Shell
« Reply #1 on: January 14, 2012 - 09:16:23 PM »
only in the 70 to 71 bolts  :faint: really 90% to 10% in difference or less  :2cents:
72rtchallenger
what happens in the garage
stays in the garage
Offline TreeFrog
    • TreeFrog
Re: 72-4 Shell
« Reply #2 on: January 14, 2012 - 09:48:09 PM »
I am guessing the front bumper mounting holes are different, outside of that I am clueless
Re: 72-4 Shell
« Reply #3 on: January 15, 2012 - 07:17:57 AM »
Stripped to the shell, I would think they are no differences '72-74.
72-74 bumper bracket mounting holes are the same. Different on the bumper but the same on the frame. Come to think of it, I've never had a '72 bracket, but 73, 74 are definitely the same on the frame.  :2cents:
Re: 72-4 Shell
« Reply #4 on: January 15, 2012 - 08:24:25 AM »
I would tend to disagree , the 72 had flush bumpers , the 73-74 had the extended bumpers on the front but the 74had a huge beam in behind the rear bumper with totally different mounting , the 74 I had was 3800 lbs with a small block & I had removed the bumper re-inforcements !! BY comparison my 70 is 3550 with a big block so there had to be a lot more metal somewhere in the car
Re: 72-4 Shell
« Reply #5 on: January 15, 2012 - 10:08:49 AM »
But the mounting holes on the uni-body are in the same place. Brackets are different but the shell is still the same. No?
Offline TreeFrog
    • TreeFrog
Re: 72-4 Shell
« Reply #6 on: January 15, 2012 - 11:15:13 AM »
I was considering looking for a 72 shell, and prep it. then strip my 72 and move all the parts over.
I feel certain from memory the 74 is different, the 73 may just have been in bolting the front bumper.
Thought I would ask the experts
  • 72 to 70 clone
    • cardomain
Re: 72-4 Shell
« Reply #7 on: January 15, 2012 - 12:40:18 PM »
I think the shell should be the same
72rtchallenger
stays in the garage
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
Re: 72-4 Shell
« Reply #8 on: January 19, 2012 - 11:00:54 AM »
I cloned my 74 challenger to a 70 and used the 70-71 backets and bumper and it mounted fine.
Re: 72-4 Shell
« Reply #9 on: January 19, 2012 - 04:14:32 PM »
Only minor stuff will be different.  There will be a few small holes drilled in different places between the years.  All the main stuff will be the same.
73 also has a large reinforcement behind the front and rear bumpers.  They are very heavy.  74 might be heavier...I don't know.
Offline Todd DesMarais
Re: 72-4 Shell
« Reply #10 on: January 19, 2012 - 07:14:44 PM »
 I've had/done both so I will spill the beans....
 ***NOTE*** this is for a 'cuda
 *accy/bracket mounting holes in the front inner fenders
 *trunk lock hole (72 = small, 73-4 = big)
 *rear inner frame rail reinforcements (73-4 have thick "plates" welded inside framerails)
 *quarterpanel to bumper "lip" (72 quarter has a sheetmetal lip to close the gap between the bumper and quarter; 73-4 don't, they use the thick rubber spacer)
 *slot in pass rear frame for evap. lines on 72, none on 73-4
 I think that's all. the bumpers are all in the brackets. the 74 doors have side impact bars in them = heavy
 The rest is cosmetic bolt on stuff
« Last Edit: January 19, 2012 - 07:16:18 PM by Todd DesMarais »
74 'Cuda                       "There's a fine line
66 Belvedere II               between a hobby
66 Satellite                    and a mental illness"
05 Ram 3500 CTD
Offline Brewster_440
Re: 72-4 Shell
« Reply #11 on: January 20, 2012 - 01:50:18 PM »
in 1973 the car makers were trying to add those huge goofy looking bumpers for government saftey regulations. I think they had to add other strength into the body, like the difference between a 70 hood and a 72 hood is the underhood bracing is different. the 72-74 has those "fold indents" (i don't think that's the actual name or term...) so the hood would fold in an accident instead of snapping off the hood springs and coming thru the windshield.  My car is a 1970 Challenger and has large formed steel bracing inside the doors, and maybe its 1/8" thick. I believe that brace is thicker and heavier on a 1972 Cuda. so there would be some of that extra weight.
1968 GTX 426 Hemi - gone
1967,65,72 Darts - gone
1970 Challenger - current project
First time behind the wheel of a car was in a 1973 Chrysler Town & Country w/440 on Daytona Beach
Offline TreeFrog
    • TreeFrog
Re: 72-4 Shell
« Reply #12 on: January 20, 2012 - 02:16:10 PM »
Just to be clear .....
I am looking at the basic shell only.
doors, truck lid front clip EVERY THING ELSE is GONE...
Just the UNIBODY SHELL (not that I have found one)
Re: 72-4 Shell
« Reply #13 on: January 21, 2012 - 01:02:45 PM »
as I recall I had to cut sections of the rear bumper beams to mount the rear bumper after removing the beam , but I an sure with 70 mounts the bumper could be bolted up flush but you may have to drill holes in the correct place
Offline daburford
Re: 72-4 Shell
« Reply #14 on: January 21, 2012 - 02:57:51 PM »
I've got a 74 that I've put 70 bumpers on, as well as a 70 grille. It's all just bolt on using the existing holes in the shell, and 70 brackets. The rear 74 bumper can't be used w/ 70 brackets at all. The front 74 bumper can be used with the 70 brackets, you just need to remove the 5mph reinforcement steel. And you will have two extra bolt holes you will need put bolts in for cosmetic reason (on top of the bumper I believe) or just get a 70 bumper. No drilling, no metal modification. There are holes in the rear side quarters that the big rubber pieces bolted through into the trunk you will need to fill on the 73/74 shell or risk water leaking in through those.
1974 Dodge Challenger Rallye 360, Slapstick Auto, 3.55 Suregrip, Yellow Blaze on Black Vinyl, 1970 Grille, 1970 bumpers, 1970 T/A Spoilers
1986 Porsche 928S 5-Speed, Limited Slip, White Gold Metallic on Chocolate All Leather, Chipped, externally adjustable Koni's, short throw shifter, rear muffler bypass, and more mods
1987 Jaguar Series 3 XJ6, Solent Blue on Biscuit Leather, bad #5 exhaust valve
1993 GMC K1500 Suburban, Quicksilver/Dark Garnet on Silver cloth, Knock in the rear differential
1991 Volvo 740, Silver on Blue cloth, 373K Miles, daily beater
