Author Topic: Power Steering Rebuild.  (Read 719 times)
Offline dusty
« on: January 15, 2012 - 06:18:03 PM »
I've pulled the steering gear off the K member and it is currently sitting in de-greaser. I don't recall it leaking when I got the car. Should I go ahead and buy  a rebuild kit for it or clean it up and re-install once I get the car painted and hope that it doesn't leak?
I think it is in good shape, but was also wondering  if a rebuild would tighten the steering up a bit? I recall the car having some play in the steering.. Any advice most welcome.
Re: Power Steering Rebuild.
« Reply #1 on: January 15, 2012 - 06:29:53 PM »
Power steering box:
Send out to Firm Feel and put in a stage 3 kit.   :2cents:
http://www.firmfeel.com/powerst_abe.htm
Power steering pump:
You can buy a rebuild kit online.
Fairly easy to rebuild if you want to go that route. Or buy one already re built.
Offline dusty
« Reply #2 on: January 15, 2012 - 06:41:19 PM »
Thanks Topcat, I've bookmarked  them. Sounds good!
