I can't believe I'm going to ask this....
1. I took the original dust boot off of the idler arm. I assumed the arm was bad since I couldn't move the tapered end side to side like a tie rod. Looking under the boot, it doesn't look like it is supposed to move like a tie rod. There is no up and down movement that I can feel and no side to side movement. I can turn the tapered section...not easily...not hard either. I assume this means the center link end is still good?
2. When installing the idler arm in the K-member, you are supposed to tighten the pinch bolt to 65 foot pounds I think. That means the two ears on the K-member should hold the idler arm tight...meaning the idler shouldn't move back and forth inside the K-member right? It should move back and forth around the rubber bushing? How easily should the idler arm move once the pinch bolt is tight? Can I clamp the arm in a vice to make sure it moves back and forth around the bushing?
