Author Topic: Wilwoods 12.19" Rotors and 15" Mopar Rallys  (Read 779 times)
Offline bandt
« on: January 19, 2012 - 09:46:08 AM »
I am looking at Kit 140-9828-D from Wilwood.
The kit comes with 12.19" rotors that fit in some 15" wheels.
Has anyone tried installing this kit with a 15" rally wheel?  I read that  the problem occurs where the two piece rim is welded together. The corner of the caliper sits in that area where possible lumpy welds can cause a problem with clearance.
Thanks,
Brian
« Last Edit: January 19, 2012 - 02:15:54 PM by bandt »
Offline Jamie
Re: Wilwoods 12.19" Rotors and 15" Mopar Rallys
« Reply #1 on: January 22, 2012 - 06:27:54 PM »
I just found out on the rear of my car. I bought the basic just right detailing disc kit and the welded part of the rear wheels hit the corners of the calipers( just barely though) I believe the rotors are smaller than 12" so I would imagine yours will rub . My front are fine but I believe the rotor is close to stock size.I tried an aluminum wheel and the fit is fine , The weld area is what kills the clearance on steel wheels.
I will finish a project.I will finish a project. I will finish a project.
70 barracuda plum crazy
( current goal is to keep just one car) AND FINISH IT!
08 charger r/t  w/road & track package
2011 silverado
Offline bandt
« Reply #2 on: January 23, 2012 - 09:21:27 AM »
Thanks Jamie.
Brian
