Author Topic: Did I screw up my fuel system?  (Read 1182 times)
Offline Grec
« on: January 20, 2012 - 03:53:58 PM »
So... pretty shortly after I got my 73 Challenger years ago, I decided to redo the entire fuel system and set it up like a factory 440 six-pack.
Here's what I have:
70-style tank
3/8 sending unit
3/8 fuel line
1/4 return line
Six-pack vapor separator
OK... here's where I think I may have screwed up... I still have my original 73 filler tube which doesn't have a vent line that dumps out at the frame rail.
The car runs good, but DOES have a weird random hiccup / backfire in the carb that I have never been able to get rid of. This may not have anything to do with the tank / fuel line setup... but then again, I suppose it might.
I guess the real question is... even with the return line and vapor separator, do I still need some kind of vent line? What kinds of problems might not having it cause?
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: Did I screw up my fuel system?
« Reply #1 on: January 20, 2012 - 04:55:59 PM »
What gas cap do you have? Vented or non-vented?
When you take off the gas cap ( especially on a hot day) do you hear pressure releasing?
Offline Grec
« Reply #2 on: January 20, 2012 - 05:01:34 PM »
It's aftermarket and I'm pretty sure non-vented.
And no... I don't recall hearing pressure releasing.
- 440 Six Pack
« Reply #3 on: January 20, 2012 - 05:06:19 PM »
I'd say it needs to be vented somehow? Mine (1970) has CA emmisions and has 4 vent tubes coming off the tank going to a tube " thingy" in the trunk?
« Reply #4 on: January 21, 2012 - 01:16:31 PM »
if you have the 70 tank it should have the vent nipple that would connect to the line into the trunk , if the nipple is open it will still vent , & may spill fuel when full , what did you do with the nipple , is it covered ?
Are you running a six pak ?
Offline Grec
« Reply #5 on: January 21, 2012 - 09:56:48 PM »
I don't recall hooking up anything other than the fuel and return lines... Where on the tank is this nipple? It's been awhile since I installed the tank.
And yeah... I'm running a six-pack.
- 440 Six Pack
« Reply #6 on: January 22, 2012 - 10:32:30 PM »
As I recall it is high up on the right side near the filler neck as the vent line just went up to the filler neck
Offline boxfox
« Reply #7 on: February 04, 2012 - 09:33:23 PM »
I did this project last year, replaced all the same times you've replaced, but I never got a new vapor separator or return line, I just removed the return line completely. I still put the 4 hoses to the old vapor separator and then out the other side I put a small length of hose running off to the side in between the vapor separator and the fender, its been working out fine for me like that.
And by vapor separator I mean this. Posted a picture because there seems to be alot of confusion as to what these are suppose to be called and or what the actual function of them is.
I simply did away with the smog canister up front also.
Offline jimynick
« Reply #8 on: February 05, 2012 - 01:21:05 AM »
Has anybody got a good one of these? Mine is rotted, badly and I'll need to replace it. Sorry and not trying to hijack the thread, just thought it was appropriately timed. Thx. Ian
